CEL codes.... - TCCoA Forums
post #1 of 13 (permalink) Old 09-07-2006, 09:42 PM Thread Starter
SR-71Blackbird's Avatar
CEL codes....
uh i think i need a tune....just finished PI swap, i'm sure most of u read my other post, i'm the guy who bent 4 valves, lol
ne who;
PO171- system lean, bank 1
PO174- system lean, bank 2
PO302- #2 misfire
PO304- #4 misfire
and of course PO161 & PO141.....but those are cuz i deleted the rear O2's
1997 4.6L LX SPORT, rollin on 19's
http://www.cardomain.com/ride/856858
http://s12.photobucket.com/albums/a241/steviewonder13/
PI heads, PI intake, Comp 262's, Comp Valve Springs, Kooks headers, 3.73 TL, 180*T-stat, RSTB, lowered 1.5", A/C Delete Pulley, Custom exhaust. Block #2
-- SCT dyno tune 279RWHP & 310RWTQ - DD tune, SAE corrected
14.5 @ 97mph (need a higher stall, car bogged w/ stock converter + mickeys, lol)
SR-71Blackbird is offline
post #2 of 13 (permalink) Old 09-07-2006, 10:14 PM Thread Starter
could turning that screw with no head on the throttle body cause these....cuz we turned it to let more air in because it wouldn't idle
post #3 of 13 (permalink) Old 09-08-2006, 12:05 AM
The Great Obucina's Avatar
you need a tune. clear the codes after the tune and if they come back, you need o2 sensors.
"Booyah". Stu Scott.
The Great Obucina is offline
post #4 of 13 (permalink) Old 09-08-2006, 12:14 AM
Moderator & Teksid Whore
guitar maestro's Avatar
a proper PI swap would still be able to idle......it may idle funky for a while while the EEC relearns certain parameters.......if both banks are lean, and they weren't before, you may have vacuum leaks.....plenty of places to screw up for that to happen......i totally forgot to hook up the main vacuum line on the upper plenum when i did my pi swap....after i fixed that, idled just fine, even with the crower cams
cylinders 2 & 4 are not paired up in our waste spark system, so i suspect spark plugs or wires, or maybe injectors....easiest thing is to swap parts and see if the codes switch cylinders.....could also swap coil packs to see where the codes end up
guitar maestro is offline
post #5 of 13 (permalink) Old 09-08-2006, 10:22 AM Thread Starter
reset that screw, cleaned MAF, switched coil packs.....plug wires are accel, less than a year old
going to test...
post #6 of 13 (permalink) Old 09-08-2006, 10:48 AM
Faster than Porkchop
cjchevez's Avatar
Make sure you dont cook your cats ..
1997 Ford Thunderbird 4.6 Sport .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
PI heads *PI intake*Mark VIII torque converter*Cobra T-loc w\4.10's * Jmod*tranny fluid cooler*P&P stock T/B & plenum*UD pulleys* Dynotech 4in ds*80mm Lightning maf*Xcal2*02 GT intake tube.
cjchevez is offline
post #7 of 13 (permalink) Old 09-08-2006, 10:57 AM Thread Starter
i'm running open headers
it drove better. yesterday it was shuddering/missing at part thottle (1200-1500rpm) in 4th, and it's not doing that ne more
i'll read the codes again once i get out of class at 2
post #8 of 13 (permalink) Old 09-08-2006, 11:57 AM
mine did the same thing initially when i ran the 262s. After driving it around for a while, it missed less and was more driveable.
post #9 of 13 (permalink) Old 09-08-2006, 01:20 PM Thread Starter
will the rear 02 sensors work if i were to hook them up in the front spots? i think my front O2 sensors might be going because the lean code for bank 1 came back after class....
post #10 of 13 (permalink) Old 09-08-2006, 01:34 PM
not sure. You could try it, but I would rather run new o2s if the problem really is in the sensors.
post #11 of 13 (permalink) Old 09-08-2006, 03:07 PM
Why don't you put your exhaust back on? If you are running open header, then you dont have O2 sensors in the system, right? Not to mention your valves are probably hating you for driving the car with no exhaust. Don't skip out on things just because you are in a rush to drive the car. A friend of mine pretty much exploded his exhaust manifold after only 2 weeks of open header driving.
All Glory to God!
RIP JOHNNY LANGTON
96 LX PI/Jspec Pearl White. She enjoys eating ricers for breakfast
-MODS-
2002 PI 4.6L - Jspec Trans built by Darrin - 04 Marauder converter - Hayden 679 Trans cooler - Engine cooling modification - SCT Xcal2, tuned by Lonnie - 02 GT MAF and 99 GT Intake tube - removed silencer - 255 lph HP fuel pump - Aluminum Driveshaft - 3.73 TL - 245/60/15 BFGoodrich Radial T/A's - PBR front brakes - SCP Rear torsional load brace - SCP Solid rubber motor, transmission mounts - Rear Strut Tower brace and Diff cover brace by Rod
96_LX is offline
post #12 of 13 (permalink) Old 09-08-2006, 06:51 PM Thread Starter
the old exhaust will not fit......so i need to make a new exhaust
huh?
post #13 of 13 (permalink) Old 09-08-2006, 09:55 PM
Lonnie's Avatar
Open headers..... no wonder you are running lean. You need to have a closed system to get the proper reading from the O2s. It's drawing in fresh air back up the headers between each exhaust pulse.
www.blueovalchips.com
1992 5.0 Thunderbird Sport, 328 rwhp 347 rwtq
1995 Mark VIII, 287 rwhp 305 rwtq
I have seen the truth and it makes no sense
Lonnie is offline
