MAF code - TCCoA Forums
post #1 of 22 (permalink) Old 09-08-2006, 09:50 AM Thread Starter
rednsilver94sc's Avatar
Send a message via AIM to rednsilver94sc
MAF code
i was experiencing some problems with my car it would cut out around 3k rpms
i unplugged my MAF and the car would stop cutting out so i went to a junkyard and found a maf off of a 3.8 lx tbird which has the same part number maf as the 4.6
now the car is throwing a check engine light and the codes coming up maf now when it didnt previous
the tach drops to around 300 rpms upon first acceleration then drives just fine after that
is the 3.8 maf sensor calibrated for higher #injectors causing my car to bog down from to much gas? it smells like shes running a bit rich
or does this sound like another problem
rednsilver94sc is offline
post #2 of 22 (permalink) Old 09-08-2006, 03:08 PM
most likely the wrong MAF. Clean your old MAF sensor and put it back in.
All Glory to God!
RIP JOHNNY LANGTON
96 LX PI/Jspec Pearl White. She enjoys eating ricers for breakfast
-MODS-
2002 PI 4.6L - Jspec Trans built by Darrin - 04 Marauder converter - Hayden 679 Trans cooler - Engine cooling modification - SCT Xcal2, tuned by Lonnie - 02 GT MAF and 99 GT Intake tube - removed silencer - 255 lph HP fuel pump - Aluminum Driveshaft - 3.73 TL - 245/60/15 BFGoodrich Radial T/A's - PBR front brakes - SCP Rear torsional load brace - SCP Solid rubber motor, transmission mounts - Rear Strut Tower brace and Diff cover brace by Rod
96_LX is offline
post #3 of 22 (permalink) Old 09-08-2006, 03:39 PM
wilson502's Avatar
I agree with 96_LX, that MAF isnt calibrated properly for that car. Either clean ur old one, or buy a new one for your year and engine.
2007 White Ford Focus SE ZX3 Hatchback (The new driver)
1997 Alpine Green 4.6L Bird (SOLD!)
Mods:
Removed Air silencer, Clear Corners, Silverstar headlights and corner lights, Moroso Bluemax Spiral Core wires, Custom 3" Magnaflow exhaust with 2.5" Y-Pipe, 300-450 HP J-mod Kit by dirtyd0g , Hayden 30k GVWR Trans Cooler, Sport Front Suspension, 03-04 Cobra Rear Shocks, PBR Front Brake Swap, Xcal 2 by Lonnie @ Blueovalchips.com, 22C plugs, 180F T-stat, 02GT MAF/Airbox with K&N Drop in, Griffin Radiator, Cobra Water Pump
wilson502 is offline
post #4 of 22 (permalink) Old 09-09-2006, 09:23 PM
MN1293-232's Avatar
yeah i can tell you for sure the MAF is different between the 3.8 and 4.6. I got two in my hands to prove it. Anyways get the correct one and more than likely that will solve your problem.
MN1293-232 is offline
post #5 of 22 (permalink) Old 09-11-2006, 11:09 AM Thread Starter
thats what i figured but according to all data the part numbers were the same
my old maf is shot i cleaned it with no help time to go find a new one
will a 94-97 4.6 maf work?
post #6 of 22 (permalink) Old 09-11-2006, 12:41 PM
wilson502's Avatar
the 96-97 maf i believe is different than the 94-95 MAF.
Mods:
post #7 of 22 (permalink) Old 09-11-2006, 02:23 PM
The Great Obucina's Avatar
yes it is.
FYI - MAFs are not calibrated for injectors.
"Booyah". Stu Scott.
The Great Obucina is offline
post #8 of 22 (permalink) Old 09-12-2006, 01:40 AM
Both of you are incorrect. The MAF sensors in these cars aren't calibrated for the particular engines. 94-95 3.8 (N/A) and 4.6 use the same MAF but use different size injectors. The same is also true of 96-97 3.8 and 4.6 cars. The MAF delivers the same transfer function, but the computer knows based on whether or not it is a 3.8 or 4.6 computer how to interpret that data. There is no difference whatsoever between the sensors for a 3.8 and 4.6, with the exception being the 3.8 SC.
rednsilver94sc, you can use any MAF from a 94-95 bird as long as it isn't an SC.
post #9 of 22 (permalink) Old 09-15-2006, 10:06 AM Thread Starter
with the mass air connected or unplugged the car still stumbles upon take off and the codes is a mass air code
post #10 of 22 (permalink) Old 09-15-2006, 10:16 AM
put a 95-95 4.6 MAF on the car. Dont make this any harder than it should be.
post #11 of 22 (permalink) Old 09-15-2006, 11:00 AM
wether's Avatar
Has the EEC been reset since the "new" MAF has been installed? This sometimes is required (stupid computers don't do what we want them to ). Unplug the battery and turn on the headlights (with the battery unplugged) for about 5 minutes to reset the EEC.
wether is offline
post #12 of 22 (permalink) Old 09-15-2006, 11:49 AM
wilson502's Avatar
Thats what i was tryin to get at.
Mods:
post #13 of 22 (permalink) Old 09-15-2006, 12:45 PM Thread Starter
the car has been reset
but
before when the mass air was bad the car would cut out but never threw a light it wasnt until the new mass air was put on that its throwing the light with this new stumble but it is not cutting out anymore
still stumbles plugged or unplugged
post #14 of 22 (permalink) Old 09-15-2006, 05:31 PM
Lonnie's Avatar
You have to use the correct MAF. An 3.8 MAF is not in anyway the same as the 4.6. They may have the same part number because they use the same housing but that is it. You have to use a 4.6 MAF.
You are incorrect master486. Their transfer functions are totally different and the reason why he is getting a check engine light. That MAF will never work without the EEC reprogrammed with the 3.8 Meter's transfer function. rednsilver read the codes and stop guessing.
www.blueovalchips.com
1992 5.0 Thunderbird Sport, 328 rwhp 347 rwtq
1995 Mark VIII, 287 rwhp 305 rwtq
I have seen the truth and it makes no sense
Lonnie is offline
post #15 of 22 (permalink) Old 09-15-2006, 05:43 PM
95xbird's Avatar
So whould that explain why bank 1 and bank 2 are lean on my car???I swaped a 3.8 MAF in my car because it was beyond cleaning.Ever since ive had a P0174 and P0171.
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #16 of 22 (permalink) Old 09-16-2006, 01:47 AM Thread Starter
it still stumbles disconnected
it should go to default mode like it did when i unplugged the 4.6l one when it was cutting out its not doing that it still fumbles
post #17 of 22 (permalink) Old 09-16-2006, 01:49 AM Thread Starter
mines not running lean its running rich
post #18 of 22 (permalink) Old 09-16-2006, 02:42 PM
Moderator & Teksid Whore
guitar maestro's Avatar
95xbird, yes it is VERY possible that is why you're running lean on both banks
rendsilver94sc, get a stock 94/95 4.6 MAF and be done with it
guys listen to lonnie, obucina, and all others when they tell you that using a non-stock MAF WILL require reprogramming of the computer.....keep on being hardheaded like this, and people will be hesistant to help you in the future...that would be a shame because we all want as many mn12s as possible out on the streets
guitar maestro is offline
post #19 of 22 (permalink) Old 09-17-2006, 09:47 PM
Darrin's Avatar
Now thats just some wrong info right there. DO NOT listen to this information people. Anyone with any knowledge on these cars at all knows that these MAF's are not the same and are not at all interchangable.
Darrin
Darrin is offline
post #20 of 22 (permalink) Old 09-18-2006, 10:54 PM
Lonnie's Avatar
I've done some investigating since this has become a main email and PM topic for me. There are 3 MAFs that were used for the 94/95s from the factory, 3.8 used the F4SZ while the 4.6 used the F4SF and the one for a SC. They have totally different transfer function from each other, I have these at my access for those non believers. Ford now only lists 2 MAFs for these vehicles, the F4SZ and the one for a SC. No one can explain why when I talked to anyone at Ford. All they say is they now use the same one for both the 3.8 NA and the 4.6. And, if you look through any new parts interchange you will see both listed for both engines. So I'm going to assume that Ford has decided these were close enough to work in either engine and since the transfer function is in the EEC it would be safe. I guess they figured these anemic 4.6s couldn’t out flow the 3.8… This is more than likely a very rare occasion these parts actually will work so I wouldn't be going around trying other MAFs just to because this situation did work. You will more than likely do damage than good.
This doesn't solve the above problems but it is new info that could help someone. Only way to really know what is going on is to data log the vehicle during the time you having the problem and then troubleshoot the data.
Lonnie is offline
post #21 of 22 (permalink) Old 09-18-2006, 11:26 PM
Darrin's Avatar
I am honestly just going off of the different MAF transfer functions for the 3.8 and 4.6 vehicles. Different transfer functions mean different MAFs.
Darrin
Darrin is offline
post #22 of 22 (permalink) Old 09-18-2006, 11:34 PM
And I posted my info based on what is currently available in the market. I too did some investigating into parts catalogs and saw that the parts were interchangeable between the two engines. That is why I posted the information I did. I checked each year between the different engines and saw that the part number was the same, and knowing that the same part number means the same part, I deduced that the difference must lie in the EEC.
Lonnie, I don't know what the mystery is with Ford previously offering 3 and now only offering 2. I try very hard to make sure that all of the information I post on this forum is as accurate as possible, and I don't want my information to be incorrect. I would like to build and maintain a good reputation here, so if any information I provided is inaccurate, I apologize. As I previously stated, I just went off of what I saw available in different parts catalogs and my own experience.
Darrin, based on what's currently available, it would seem that the MAF sensors are interchangeable, so please don't label my information as incorrect and tell everyone to not listen to me. This goes for 91-93 3.8 N/A & 5.0, 94-95 3.8 N/A & 4.6, and 96-97 3.8 & 4.6.
