Intake Manifold Q - TCCoA Forums
post #1 of 4 (permalink) Old 09-08-2006, 09:54 AM Thread Starter
Tx_Cat's Avatar
Intake Manifold Q
Question guys, this will be the 3rd time we have changed the manifold on my dads 96 cougar, so I was wondering if the manifold from a 01 Crown Vic, Mercury Grand Marquis and Town Car will work on the cat?! The last one cracked were the nipple on the back is, but the whole front is in good shape. I posted a thread here a couple of months back, and 6 out of the 8 plugs were filled with antifreeze. Thanks
Israel
Tx_Cat is offline
post #2 of 4 (permalink) Old 09-08-2006, 09:59 AM
Traveler's Avatar
That stupid nipple is leaking on my manifold to. Its a slow leak so I've gotten lazy about replacing the manifold. But every month or so I have to pull the plugs on the passenger side, and clean them out with compressed air.
I think that all the manifolds are the same, however because they are all the same I don't think that any one is more or less likely to crack than another.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #3 of 4 (permalink) Old 09-08-2006, 11:11 AM
01 will be PI, so you need to do the common stuff for putting a PI intake on a NPI engine if the 96 still has the NPI engine.
Bangster is offline
post #4 of 4 (permalink) Old 09-08-2006, 01:15 PM
ScottG29's Avatar
Send a message via AIM to ScottG29 Send a message via MSN to ScottG29 Send a message via Yahoo to ScottG29
pi
swap to a pi intake!! if you need any info on where to get a full install kit, just ask
Scott G
96 Thunderbird LX Sport 4.6L V-8 202 rwhp 276ft/tq
-March U/D Pulleys -PP Balancer -True dual flowmaster exhaust w/o cats -PI Intake -Trickflow Plentum -75mm throttle body -Cold air -90mm MAF -Tune by Livernois Motorsports -Some audio equipment -17 x 9 Cobra R Wheels -275/45 Bridgestone Potenza's -Eibach Springs -Koni Shocks -KVR Rotors -Kevlar Pads -3000 Stall -3.73 Gears -B&M Transcooler
www.livernoismotorsports.com
Mod-Motor Specialists
ScottG29 is offline
