hesitation problem, part 2 - TCCoA Forums
post #1 of 7 (permalink) Old 09-13-2006, 04:55 PM Thread Starter
Gcline's Avatar
Well, i removed my intake silencer just for the heck out of it, I figured it would make my k&N cone filter breathe easier, and it does, but there was another good side effect. My p0430 code went away, and i havent seen a check engine light for a week. Im still getting a hesitation problem though. when you dont accelerate hard, it hesitates. also when its doing this, when you go to WOT it still does it. When you start it up sometimes idles real low, then i hear a whining sound and the idling goes to normal again.
Daily Driver, 38mpg!
Gcline is offline
post #2 of 7 (permalink) Old 09-13-2006, 05:24 PM
Rolling-Thunder's Avatar
Did you ever change the plug wires?
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #3 of 7 (permalink) Old 09-13-2006, 08:46 PM
MattsLE97's Avatar
Send a message via AIM to MattsLE97 Send a message via Yahoo to MattsLE97
I would check those out first start it at night and look very very carefully at the wires for arching, especially if there routed under the alternator. I found out for whatever reason my new oem wires when to **** and were arching like no ther being routed under. You could see the electricity flowing through them
-Matt-
2000 dodge dakota 4.7L 4x4
Flowmaster 3" SI/DO 2.5
31" cooper stt tires (mud and off roading here I come)
MattsLE97 is offline
post #4 of 7 (permalink) Old 09-13-2006, 09:47 PM
I watched one of my buddies check a car just like mine at his dad's shop, looking for a leaky plug wire, by running his hand down the wires...
If Ida just had my video camera, I'd be rich from 'americas funniest home videos'.
These ignitions are hard on wires...not at all like the chevy 350's we worked on in shop class, in the '70s...
I've heard 160kV, but I'm not going to measure it!
post #5 of 7 (permalink) Old 09-13-2006, 11:04 PM Thread Starter
Gcline's Avatar
i never changed them yet, i never have anytime till the weekend. I did however water the wires to see if they would spark, but it seemed like the water just disappeared, or evaporated
Gcline is offline
post #6 of 7 (permalink) Old 09-14-2006, 06:19 AM
You have 200k miles on the wires (posted on your other thread)
You should change them and go from there.
post #7 of 7 (permalink) Old 09-14-2006, 08:20 PM
I had a very bad hesitation problem, and i changed almost everything BUT the wires. I checked the wires in the dark, with water, a couple times, and they looked fine. Finally i took it to a garage, showed him a list of what i did, and $60 later he said it was my plug wires. I didn't believe him, but i changed them anyway, and guess what, the car works perfect now.
the moral of this story is: change your plug wires!
mattcorby is offline
