Starting Problem - TCCoA Forums
post #1 of 4 (permalink) Old 09-15-2006, 10:13 AM Thread Starter
Me007gold's Avatar
Send a message via AIM to Me007gold
Starting Problem
well guys i got my car a little over two weeks ago, everything has been fine and good till this morning. go out to start it, click click. ****. turn the car into accessorys and the radio comes on, lights works everything works but it will not start when ever i hit a button or use the turn signals the volt meter jumps a bit. get a jump. after i get the jump runs good for about 10-15 minuits with the volt meter jumping all over the place and my climate control shuting it self off every few secons, then it died. i am guessing it is probley the alternator. battery terminals are clean, the ground is good. what would be your sugestion?
Theres nothing better than having a lower roof line than a civic, and a longer wheelbase than a van.
Me007gold is offline
post #2 of 4 (permalink) Old 09-15-2006, 10:54 AM
wether's Avatar
Using a multi meter can you get a voltage reading from the battery with the car running?
wether is offline
post #3 of 4 (permalink) Old 09-15-2006, 02:50 PM
Moderator & Teksid Whore
guitar maestro's Avatar
with the key in the crank position, check the voltage at the battery (whether it cranks or not).....voltage should not fall below 10.5V....ideally it should stay above 11V.....if it is in the vicinity of 10.5V or lower, battery is bad and/or cables are corroded inside the insulation and/or are not tightened down properly
guitar maestro is offline
post #4 of 4 (permalink) Old 09-15-2006, 02:57 PM Thread Starter
Me007gold's Avatar
it was a combo of both battery and altenator, so its being fixed as we speek
