white smoke - TCCoA Forums
post #1 of 16 (permalink) Old 09-16-2006, 06:10 AM Thread Starter
white smoke
everyonce in a while when i rev it up white smoke come out of the exhaust and ideas? 94 4.6 78000 miles on it
lpfan is offline
post #2 of 16 (permalink) Old 09-16-2006, 10:25 AM
Fry Rice Specialist
Casper's Avatar
worn valve seal. the smoke came out especially idle for a while right?
94-95 v8 are notorious for this problem.
CarDomain Page
Casper is offline
post #3 of 16 (permalink) Old 09-16-2006, 01:40 PM
jesusraybrown's Avatar
Casper's right.
1. This forum requires that you wait 30 seconds between sending private messages. Please try again in 266079416 seconds. wtf?
jesusraybrown is offline
post #4 of 16 (permalink) Old 09-16-2006, 06:46 PM Thread Starter
i think its mostly when i rev it up is it hard to change the valve guide seals?
lpfan is offline
post #5 of 16 (permalink) Old 09-16-2006, 08:05 PM
tbirdgirl94's Avatar
Send a message via MSN to tbirdgirl94
if its white smoke then you got head gasket problems or a dirty maf.
if its blue smoke then you valve seals are bad.
if it was cool out and you seen the steam from the exhaust then that is a different story. all exhaust makes whitish colored smoke when its cold.
tbirdgirl94 is offline
post #6 of 16 (permalink) Old 09-16-2006, 11:40 PM
The blown head gasket smoke is very white; and doesn't quit, mine covered both lanes behind me...(83 firebird)
The valve stem seals on these leak and cause bluish-white smoke when you pull out after a throttle closed stop, or after a long coast downhill.
If its continuous, I'd check the plugs for oil fouling; broken rings are possible, but not really likely at 78k. These engines aren't well known for head gasket probs, but the valve stem seals is a known thing.
My red car, at 190k is smoking from the valve stem seals, but it doesn't show on the plugs... yet, anyway. my black one doesn't at all, at 115k.
If all the plugs look good, you are probably fine. They should all look alike, a light tan. If one is extermely clean, like steam-cleaned clean, you could have a head gasket problem. The cylinder with the leak will look pristine from being steam cleaned from the inside...
post #7 of 16 (permalink) Old 09-17-2006, 02:43 PM
Tx_Cat's Avatar
CHANGE THE GASKET ASAP if you dont want your engine to go bye bye like it did with me. My engine had like 55k when the stupid gasket failed and POOM..... White smoke like a mofo popped out my mufflers....
Tx_Cat is offline
post #8 of 16 (permalink) Old 09-17-2006, 09:39 PM
Fry Rice Specialist
Casper's Avatar
to know if it's blowing headgasket check your oil if it's muddy color.
CarDomain Page
Casper is offline
post #9 of 16 (permalink) Old 09-18-2006, 02:18 PM
Silenced's Avatar
Puffy white cloud comming out of your exhaust = Oil. My buddy busted one of our test oil-return hoses on his turbo last night, so oil sprayed all over the outside of his turbo and burned. It put out a solid white puff of smoke that covered the entire gas station parkinglot.
Silenced is offline
post #10 of 16 (permalink) Old 09-18-2006, 02:58 PM
02 Explorer Pioneer
timb's Avatar
Since I see you have a 94 with about 80K walk around back and see if you have fuel dripping out the pipes. 94's were known to throw an injector driver around 80K and hold an injector or two wide open which pours fuel in and causes lots of white smoke and rough running.
Birdless
timb is offline
post #11 of 16 (permalink) Old 09-19-2006, 04:40 AM Thread Starter
it runs like a champ to me i think so to smell of gas or anything if i had a guess it would be the fuel filter makin it run lean its a b*tch to start i have to crank it and crank it there is no way ill get a remote starter on it as is its like the fuel filter doesnt let the fuel pump prime the vehicle
lpfan is offline
post #12 of 16 (permalink) Old 09-19-2006, 09:42 PM
Try swapping your EEC with someone elses and see. Also check injectors. I had same prob and it turned out to be stuck injectors because EEC went bad. Changed it and no more smoke.
1995 pearl white LX 4.6L bird
SOLD to good home
Assorted parts for sale email [email protected]
www.racingsyndicate.net Check it out!
JuniorBirdman is offline
post #13 of 16 (permalink) Old 09-19-2006, 09:44 PM
And true that valve guide seals are also famous on the V8, but hope for the injectors as they are much much easier to replace. I would also recommend a compression check just to make sure you havent busted the gasket between cylinders
SOLD to good home
post #14 of 16 (permalink) Old 09-20-2006, 01:00 AM
Fry Rice Specialist
Casper's Avatar
the ford fuel injectors are hard to kill. you'll wear out the rubber pedal boot before the fuel injector took a dump.
CarDomain Page
Casper is offline
post #15 of 16 (permalink) Old 09-21-2006, 08:03 AM
death1880's Avatar
Send a message via AIM to death1880 Send a message via Yahoo to death1880
hey if you have gas coming out of the exhaust also it's the damn EEC so check if there is gas leaking out
death1880 is offline
post #16 of 16 (permalink) Old 09-24-2006, 10:29 PM
My car has done this for months too. If I sit idling for very long, it puffs out smoke when I finally do take off. Has anyone had it be bad enough they actually had to go as far as having to change the seals? Im just going to live with it for now until I really need to take apart the motor for a rebuild.
95Tbirder is offline
