new alternator and still not charging right - TCCoA Forums
post #1 of 12 (permalink) Old 09-17-2006, 11:26 AM Thread Starter
jda95bird's Avatar
So one week after the alt went out on my V6 I notice the battery light was on in my V8. The voltmeter was running low so I turned on my CD player which has a built in voltmeter. It was staying at around 10-10.5. I made it home and parked it since I had to head to work that night and didn't have the time to mess with it.
So a week or so later I got around to changing the alternator and I'm still having the same problems. The battery light is still on and the voltmeter on my CD player is reading about 11.
Does anyone have any ideas? I'm not a genius by far when it comes to cars but I try to do all of my own work for the learning experience and the charging system seems pretty straight forward.
The only other thing that I can think of is the belt might be slipping. The belt was put on when I did the engine swap which means it has less than 5000 miles on it but I had a power steering leak(mercon V) that was causing the belt to wear and spraying black dust. It's possible that the belt has stretched from that. I picked a new one up this morning but haven't had a chance to change it yet.
94 Thunderbird 3.8 daily driver stock with Xenon body kit and wing
95 Thunderbird 4.6 PI Explorer swap with Kooks headers, 2.5" dual exhaust, marauder converter, and Jmod
jda95bird is offline
post #2 of 12 (permalink) Old 09-17-2006, 11:45 AM
kermit's Avatar
Send a message via Yahoo to kermit
could be....if you replaced the alt and it is still doing it, try a belt.
Jamie
'96 Thunderbird LX 4.6L
'07 Eddie Bauer Explorer 4.6L 3v
'06 Mustang GT 4.6L 3v 5 spd
"10 in the tank, 4 on the floor"
kermit is offline
post #3 of 12 (permalink) Old 09-17-2006, 12:51 PM
Me007gold's Avatar
Send a message via AIM to Me007gold
could it be a defective alternator?
Theres nothing better than having a lower roof line than a civic, and a longer wheelbase than a van.
Me007gold is offline
post #4 of 12 (permalink) Old 09-17-2006, 12:55 PM
FordFanatic's Avatar
why dont you take it to autozone and have them test the charging system?
FordFanatic is offline
post #5 of 12 (permalink) Old 09-17-2006, 02:41 PM
Tx_Cat's Avatar
There is a "Master Fuse" that is located were the main harness on the trunk. If that fuse went bye bye, you can have a new alt and new battery and it will drain on you. Check that fuse and just to be sure, check your grounds. Any acid on the terminals?
Tx_Cat is offline
post #6 of 12 (permalink) Old 09-17-2006, 04:24 PM Thread Starter
jda95bird's Avatar
I'm going to change it in the morning.
It's having the same symptoms that it had before I changed it. I'll probably pull it off and switch it out if changing the belt doesn't work.
I have no faith in those machines. Two days before the alt on my V6 went out I had it tested and there was no problems with it and it was supposedly running at 14 although the gauge was telling me different. I already knew it was going out.
Where exactly is this fuse? Terminals are clean. I took the wire brush to them the other day.
post #7 of 12 (permalink) Old 09-17-2006, 09:43 PM
Fry Rice Specialist
Casper's Avatar
did you forgot to reconnect the small plug wire on the altenator?
CarDomain Page
Casper is offline
post #8 of 12 (permalink) Old 09-17-2006, 10:50 PM
whitecoug's Avatar
Send a message via AIM to whitecoug
Test the battery as well.
1994 Mercury Cougar XR7 4.6L Special Edition
PnP'd NPIs, PI Cams, PI intake, 80mm GT MAF, 24# Injectors, Shorty Headers, SCT Tuned, Jmod, Trans Cooler, 3.73's, Underdrives, Zex Dry kit 75 shot, Dirtydog TC, Trans built by Darrin, 97 Cupholders
219 RWHP/256 RWTQ NA
280 RWHP/343 RWTQ Bottle Fed (75 shot)
[email protected] mph 5/20/06
I feel sorry for the people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day.
whitecoug is offline
post #9 of 12 (permalink) Old 09-18-2006, 12:40 AM
Moderator & Teksid Whore
guitar maestro's Avatar
guitar maestro is offline
post #10 of 12 (permalink) Old 09-18-2006, 07:23 AM Thread Starter
jda95bird's Avatar
I thought about the battery last night. It only has about 5000 miles on it also. I put it in right before I did the engine swap. But it should be under warranty so it won't cost anything.
post #11 of 12 (permalink) Old 09-18-2006, 01:24 PM
also grab a sharp utility knife and cut a slit down the power and ground wires (as far away as you can from the battery terminals)....if you see green buildup instead of bright shiny copper, cables could be suspect to corrosion
post #12 of 12 (permalink) Old 09-20-2006, 09:09 AM Thread Starter
jda95bird's Avatar
Thanks for the help guys. I figured it out this morning. It was the 15 amp generator fuse under the hood. I checked all of the fuses the other day and some how I completely overlooked it. I knew it was going to end up being some small stupid BS that I was overlooking or just didn't know about.
