rough start - TCCoA Forums
post #1 of 3 (permalink) Old 09-20-2006, 04:03 AM Thread Starter
rough start
when it first started it was only after the car sat for a long time but now its almost everytime it is gettin colder here now if that has anything to do with it but it makes this wierd clanking like lifters tappin or something any ideas?
lpfan is offline
post #2 of 3 (permalink) Old 09-20-2006, 05:56 AM
When does it make that noise? If you are talking about DIRECTLY after the engine starts, that's the oil coming up to the top of the engine. Not the greatest design/sound, but it has to happen. Too thick of oil will cause your chain to wear out fast/cause other premature damage. I use 10w-30, although I should probably be using 5w-30. Now that this cold weather is coming on, I will probably use 5w-30 for sure the next time I change my oil.
On my 4.6, when I crank it in the morning, or after it hasn't been running for 2 or 3 hours, I have to hold the starter over for around 4 seconds before it cranks. Now, if I'm cranking it up after 10 minutes or so of being running, it will crank up instantly. Anyone know what that could be? Weak fuel pump? Clogged fuel filiter? I didn't have the special tool to take the fuel filter off, but I have a new one sitting here.
BTW, speaking of special tools. I hate changing the brakes. TWO different caliper bolts? WTF?!?! The star bit one was already stripped out when I went to take it out, so I had to fit a pipewrench around the outside of it (worked perfect). THEN I had to use a 3/8" socket (which, thank god, worked perfectly, too) on the top caliper bolt that requires a tool that I haven't seen. Well, it didn't LOOK like a normal hex head to me. I dunno, it was dark, but the 3/8" fit. Ok, enough rambling about brakes.
IcemanV8 is offline
post #3 of 3 (permalink) Old 09-20-2006, 10:11 AM
wether's Avatar
The bolts can be replaced by buying a "brake hardware kit" for the front brakes. The internal star head bolt is a T-50 if I remember corectly and I am not sure what size the external star bolt is. They sell a special set of sockets for brakes. If I remeber I paid $15-$20 for this set of sockets. It has been well worth it since everyone and their dog seems to ask me to "help" them change the brakes on their vehicles.
This definately sounds like an oiling issue. In colder weather make sure that 5w oil is used and not 10w. This can also be more pronounced if parking on a hill and/or a low oil level so the pick up is not "constant" when the engine first fires/turns over. Check the oil level and see if you maybe a quart or more low on oil!
wether is offline
