96 lx wiring - TCCoA Forums
post #1 of 12 (permalink) Old 09-21-2006, 08:02 PM Thread Starter
5oh Transformer
ZeroRain's Avatar
Send a message via AIM to ZeroRain
96 lx wiring
i have a 96 lx with the 3.8 and i have a chance to get a 95 xlr with a 4.6. would the wiring from the cat plug and play with the bird?
1996 Ford Thunderbird LX EFI Swapped 311 5spd "TT 5oh project"
1998 Ford Taurus SE 24v Duratec auto "DD"
1966 Ford Galaxy 500 352 Cruise-O-Matic "Restoration Car"
We don't just dream about fast toys, we build them!
ZeroRain is offline
post #2 of 12 (permalink) Old 09-21-2006, 08:50 PM
In a word, no.
-Rod
post #3 of 12 (permalink) Old 09-21-2006, 08:52 PM Thread Starter
5oh Transformer
ZeroRain's Avatar
by plug and play i mean the main harness under the hood. could i strip the underhood wiring from the 95 and hook it up into the 96 or would that require splicing
ZeroRain is offline
post #4 of 12 (permalink) Old 09-22-2006, 02:38 AM
I know that for the 3.8, the connectors changed for the sensors from 95 to 96. I would assume the same is true of the 4.6. I know the MAF sensor plug changed for the 4.6 from 95 to 96, so I'll assume that other things like the IAC, TPS and many other connections changed as well. So assuming that is the case, no you wouldn't be able to use it without splicing a new connector onto each and every sensor/component for the engine that is different.
post #5 of 12 (permalink) Old 09-22-2006, 05:27 AM Thread Starter
5oh Transformer
ZeroRain's Avatar
you guys are still thinking that i want to use the orig 3.8 engine bay wiring. what i want to do is pull the engine bay wiring from the 95 and put it into the 96. would that work plug and play wise
ZeroRain is offline
post #6 of 12 (permalink) Old 09-22-2006, 05:27 AM
See post #2.
-Rod
post #7 of 12 (permalink) Old 09-22-2006, 11:29 AM
Oh ok. Now that I see that, no it wouldn't be a plug and play deal. There's a few issues with that. If I'm not mistaken, I believe the wiring that goes from the underhood connector to the computer is different. Also, you'd need to get change the wiring to the MAF sensor area because in 95, the cars still used an EDIS module for spark control. I'm not sure what else you'd run into.
post #8 of 12 (permalink) Old 09-22-2006, 05:26 PM Thread Starter
5oh Transformer
ZeroRain's Avatar
damn i was hoping for an easy swap over for that nice old v8. if i can get the car i guess i will turn it into a drag car because she is kinda rough. or i could sell it on here.
ZeroRain is offline
post #9 of 12 (permalink) Old 09-22-2006, 10:46 PM
Don't know about MN12s but...
On my firebrd I usta own, there was a different stackup in the unibody for the V8 engines... frame flex from H*ll with a V8 in a V6 car...in the V8's there was an extra 18 gauge pan welded in.
not sure about ours, tho...
Whats wrong with the V8 car?
post #10 of 12 (permalink) Old 09-23-2006, 05:43 PM Thread Starter
5oh Transformer
ZeroRain's Avatar
the body is rough as help and i just like the degreed window on the birds
ZeroRain is offline
post #11 of 12 (permalink) Old 09-23-2006, 09:51 PM
If you have the whole car...
You can definately swap them; you might have to swap the whole wiring harness, but WTF...these V8s rock!
I'd look at the electronic modules' wiring, and decide how much you need to swap, and whether you want to spend that much time...
It would surprise me if no one else had ever done this, with all the other swaps I see here...
post #12 of 12 (permalink) Old 09-24-2006, 12:33 PM Thread Starter
5oh Transformer
ZeroRain's Avatar
right eight but im saying what the hell and im going to finish my carbed 5oh swap for this one then
ZeroRain is offline
