i need help 351C - TCCoA Forums
post #1 of 19 (permalink) Old 09-22-2006, 06:49 PM Thread Starter
winkysrides's Avatar
Send a message via AIM to winkysrides
i need help 351C
hi i have a 351C i what to drop in to my 95 t-bird
has any 1 done it before??
  • "Chuck Norris built my shortblock. It runs on the tears of small children and makes 10,000 hp. He said it's his 'street version' "
wheel hoppin and poppin!
91 Thunderbird sport 357W 5speed
88 stripped out 5.0 C4 and 4:56 gears in a 9in Ford
winkysrides is offline
post #2 of 19 (permalink) Old 09-22-2006, 07:44 PM
PDL2MDL
krazy4's Avatar
i don't think ive seen one. it would also probably help if started out with a non-modular bird.
I would love to see a cleveland bird though
DO IT!
http://www.youtube.com/watch?v=oMjdto07tuk
LX w/ true duals, cutouts
cone filter
Bird is gone replaced by an LS1.
krazy4 is offline
post #3 of 19 (permalink) Old 09-22-2006, 08:56 PM
ThunderBeast86's Avatar
Send a message via AIM to ThunderBeast86
it is being done.
Blah...I forget the name, he is a michigan boy though.
Search for 351C, his signature talks about he progress on his 351C.
Use the search button.
2.25" True Dual Catless DI/DO Magnaflow Exhaust, Eibach Springs, Addco 1 3/8", J-mod, Viper 791 Alarm, Clarion 855 full color touch-screen, Directed 2400 amp , 2 12" CV Strokers with a custom ported box, K&N air filter, 180* T-Stat, Xcal2 SCT TUNED BY LONNIE 17 x 7.5 (245/45/17) Chrome Cobra R's, 17x9 in back(275/40/17)
DOHC sitting in the garage
Teksid 2v plans?!?!
Tranny Cooler, Dual Remote Oil Filter waiting for install
ThunderBeast86 is offline
post #4 of 19 (permalink) Old 09-22-2006, 09:49 PM
David_viny's Avatar
If you’re going carb, I don’t think it matters what year Bird you use. I’m not familiar with the 351c, but if it uses standard Windsor motor mounts and transmissions, then it shouldn’t be too difficult.
1995 T-bird 4.6l - Eibach lowering springs, Cobra R hood, One 12" sub woofer, Alpine type-R front speakers. 16.249 @85.11mph 1/4 mile
2001 Pontiac Trans Am WS6 - Cam, headers, HPtuned by me.
David_viny is offline
post #5 of 19 (permalink) Old 09-22-2006, 10:35 PM
I don't remember if he is running a Cleveland or Windsor, but 95badbird has a 351 in his 95 LX.
-Rod
post #6 of 19 (permalink) Old 09-22-2006, 10:37 PM
PoweredBy351C is his name. He's done the swap. Once upon a time, the same thought had crossed my mind.. but alas, I live in NC where those horrid emissions inspection things exist. Shame. Check out the 5.0/5.8 forum.. there have been threads there. You'll find more 351W folks than 351C folks there.. but don't let them talk you out of it :P I, for one, am for the 351C.. especially with a new block being in development.. revival approaches.
a black car.
Sophosis is offline
post #7 of 19 (permalink) Old 09-29-2006, 03:56 PM Thread Starter
hey thanks guys
post #8 of 19 (permalink) Old 09-29-2006, 07:32 PM
jk69cat's Avatar
its one thing that you have it, you need to find a tranny that will bolt up thats leaves c4 and c6, you will have to custom make headers to fit this car, the motor mounts off a 91-93 5.0 car will fit, but for 91-92 you can only use the top plates. yes people have carbs on some of these, being yours is a v8 car, stay with a 4.6 and leave the swap for a v6 car. i dont like clevlands or m's and i personally think its a waste of time . but its your car
mn12 less!
jk69cat is offline
post #9 of 19 (permalink) Old 09-29-2006, 07:57 PM
Awaiting E-Mail Confirmation
tinman_72's Avatar
Originally Posted by jk89cat
its one thing that you have it, you need to find a tranny that will bolt up thats leaves c4 and c6...
...or AOD.
tinman_72 is offline
post #10 of 19 (permalink) Old 09-29-2006, 08:30 PM
The Great Obucina's Avatar
are you absolutely sure you want a 351?
"Booyah". Stu Scott.
The Great Obucina is offline
post #11 of 19 (permalink) Old 09-29-2006, 10:49 PM
yes
oh, the other guy.
post #12 of 19 (permalink) Old 09-29-2006, 10:57 PM
jk69cat's Avatar
Originally Posted by tinman_72
...or AOD.
aod wont bolt up to a c or m , they use the 429/460 bell housing
mn12 less!
jk69cat is offline
post #13 of 19 (permalink) Old 09-30-2006, 12:11 AM
tinman_72's Avatar
The 351 Cleveland uses the small block Ford pattern. Proof.
post #14 of 19 (permalink) Old 10-07-2006, 03:51 PM Thread Starter
eather that or buld up a turbo 4.6W
if i whated to be that same as every1 els i would buy a fox sting
post #15 of 19 (permalink) Old 10-08-2006, 10:36 AM
jk69cat's Avatar
i was thinking the m had the same as a c, my bad
mn12 less!
jk69cat is offline
post #16 of 19 (permalink) Old 10-08-2006, 10:44 AM
find a '93 tbird/cougar V8, for parts , and go that route. plus you get the AODE that will bolt directly to your 351C. of course while the tranny is out you can find a 4R70W and swap all the internals. you can carb it , but i think emission & performance wise you'd be better off with the EFI.
termyt00 is offline
post #17 of 19 (permalink) Old 10-09-2006, 05:10 AM
tinman_72's Avatar
It is easy to see how they could be mixed up. It shows the 302 Cleveland as having the big block pattern.
On a side note that has almost nothing to do with this thread, Wikipedia shows that the first two casting runs of the 4.6 have the SBF pattern. (IE: same as a 302.) I have never heard that before. That could certainly make things easier for putting a modular into an older car.
post #18 of 19 (permalink) Old 10-09-2006, 05:28 AM
Yep, those were the '92 Crown Vic 4.6L's.
-Rod
post #19 of 19 (permalink) Old 10-23-2006, 05:19 PM Thread Starter
hey guys thnaks for all your help but dad talked me into a 4cam mark8 motor
