Changed my dads intake manifold.... AGAIN! - TCCoA Forums
post #1 of 14 (permalink) Old 09-23-2006, 11:50 AM Thread Starter
Tx_Cat's Avatar
And I am having problems, again. After he swap I fired it up and took me a while for the car to start up, after we finally did, the car was shaking like a mofo, so we let it idle for a while. After 20 mins or so, car was still real shaky and when we wanted to move it into the garage, the car would just die. I've checked every vacum and everything is connected. What I am going to do, is to check the plugs and cables (even though I change the plugs lile 1 month ago and since then never used the cat) and see what is up. What else should I be looking for?!
Tx_Cat is offline
post #2 of 14 (permalink) Old 09-23-2006, 01:08 PM
check your plug wires....
you might have crossed them
or check for a leak in the manifold....spray it down with berryman b12 while running...see if its leaking
just ideas....
tlpru is offline
post #3 of 14 (permalink) Old 09-23-2006, 02:50 PM
Refrigerator Raider Hater
GreenBird's Avatar
propane works a lot better for finding leaks.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #4 of 14 (permalink) Old 09-24-2006, 08:28 AM
Yep, mixed up two of the plug wires.
'97 XR-7 Sport w/4.6-- guess what color!
laser_red is offline
post #5 of 14 (permalink) Old 09-24-2006, 03:52 PM
well hopefully you bought an intake with an aluminum cross over this time. it will keep you from having to swap them out.
FunktasticLucky is offline
post #6 of 14 (permalink) Old 09-24-2006, 04:00 PM
MattsLE97's Avatar
Send a message via AIM to MattsLE97 Send a message via Yahoo to MattsLE97
if u took your plug wires off to change the intake u didnt need to
-Matt-
2000 dodge dakota 4.7L 4x4
Flowmaster 3" SI/DO 2.5
31" cooper stt tires (mud and off roading here I come)
MattsLE97 is offline
post #7 of 14 (permalink) Old 09-24-2006, 05:18 PM Thread Starter
Tx_Cat's Avatar
Last intake I had the alum cross but it started to leak from the nipple. I re-checked everyting I it "works" better than the last time I started the car, now I need to replace the air intake hose, it is still missing so we will see what happens!
Tx_Cat is offline
post #8 of 14 (permalink) Old 09-30-2006, 04:24 PM Thread Starter
Tx_Cat's Avatar
Ok, I am pissed and the damn stupid car wont work properly. I re-torque the intake to 18lbs, checked all of the vacum hoses and the car idles a lil funky and when I accelerate, it bogs down a little and to make matters worst, the stupid fan will not turn on. I had to change the sensors because I could not take them out the old intake so I bought new ones at vato zone. What else could I look for?! I checked the cables and they are in order, also, when I took a plug out, the damn thing broke, nothing went into the engine.
Tx_Cat is offline
post #9 of 14 (permalink) Old 10-01-2006, 04:17 PM
spray the intake and throttle body down with b12 chem tool....while the engine is running....(not when it hot) just first thing in the AM...
your looking for a change in rpm....if you get one you have a airleak in the mantifold gasket....
if thats good....
then inspect your spark plug wires....make sure they are connected to the plug good...and TRIPLE CHECK that you dont have one crossed....thats all it takes
perhaps also you may need new plugs and wires......
tlpru is offline
post #10 of 14 (permalink) Old 11-23-2006, 12:52 PM
rjstat's Avatar
Send a message via AIM to rjstat
I just changed mine and have the same problem did it get fixed and what was the problem. I did the propane check I checked all the vacum lines made sure no cracks and no leaks I checked plug wires but there close to 25000 miles on them and the plugs
97 - 4.6L Alpine Green Cougar XR-7 w/ Fiber Concepts Hood, SPC cold air intake, 2.5 SLP Dual Exhaust, Eclipse CD4000 w/ Polk's speakers, Koni Shocks, 11/4" Addco sway bars, and Vogtland more to come.
05 - 5.4L Black Eddie Bauer Expedition loaded
rjstat is offline
post #11 of 14 (permalink) Old 11-23-2006, 01:21 PM
Boost Happy
Jurgen's Avatar
Send a message via AIM to Jurgen
check all the plug holes and make sure theres no coolant in them .
1994 Ford Thunderbird
2002 Corvette Z06
Yeah I got a few mods.And Some More
http://www.cardomain.com/ride/239875
Jurgen is offline
post #12 of 14 (permalink) Old 11-23-2006, 04:21 PM
rjstat's Avatar
I did notice when I pulled off the boot on the #5 plug that it was wet I get the compressor and blow it out. Thanks
rjstat is offline
post #13 of 14 (permalink) Old 11-24-2006, 06:29 PM
rjstat's Avatar
Well here is the scoop there was coolant in plug 5, 6, & 7 so I blew out the spark plug well of any fluid that was in there. I decided that I would replace the plugs and wires and was I glad I did. Bank # 2 looks like it was running rich plug 5 was the worst of that side. Bank # 1 looked like it was running lean the # 1 plug had a worn electrode. The car now has more power and gets off the line a lot faster and ran a lot smoother. Thanks for all your help
Ralph
rjstat is offline
post #14 of 14 (permalink) Old 11-24-2006, 06:30 PM
Boost Happy
Jurgen's Avatar
That happens alot coolant getn on the plug holes and they run like *****
2002 Corvette Z06
Jurgen is offline
