idler pulley - TCCoA Forums
post #1 of 4 (permalink) Old 09-23-2006, 02:14 PM Thread Starter
Gcline's Avatar
idler pulley
Is there any special tricks to changing the idler pulley on a 4.6? It looks pretty easy. The bearings are squealing in mine, and WD-40'ing it every week or so is getting old.
Daily Driver, 38mpg!
Gcline is offline
post #2 of 4 (permalink) Old 09-23-2006, 03:10 PM
BIG PETE's Avatar
Nope, noting tricky at all. Just use a 1/2 drive breaker bar on the tensioner to get some slack, slip the belt off, remove the idler. It's only like a $12 part. Put a little anti-sieze on the threads, bolt the new one on, put the belt back on.
No joke, it's a 5 minute job.
Pete
-97 XR-7
-5.0 Big Bore ...
Density Altitude = 4132'
1/8 mile: 8.75 @ 82
BIG PETE is offline
post #3 of 4 (permalink) Old 09-23-2006, 05:50 PM
Yup.....Piece of cake.
You know since WD-40 is a solvent you'd actually remove any lubrication in the bearing making it worse.....should have used oil.
Eric
See my Cougar at link below...
Http://community.webtv.net/EricinGreenBay/Erics1995XR7
1995 Cougar XR-7
4.6L V8
(Joel Bender Racing Member #34)
Eric420 is offline
post #4 of 4 (permalink) Old 09-23-2006, 11:58 PM
Fry Rice Specialist
Casper's Avatar
if that doesn't fixed your problem then check the pulley at the tensioner too. those may squell too and no need to buy the whole tensioner arm(unless the arm is broken). the tensioner use the same pulley as the idler pulley.
CarDomain Page
Casper is offline
