Oil pressure gauge - TCCoA Forums
post #1 of 9 (permalink) Old 09-25-2006, 09:27 AM Thread Starter
Send a message via AIM to mcate
Oil pressure gauge
96 4.6 LX w/45k miles. When braking, mostly from highway speeds, my oil pressure gauge deflects all the way left momentarily & the check gauges light comes on. I'm figuring (hoping) that it's a loose wire on the sending unit or something simple like that. Anyone else ever have this?
95 SC auto, C&L 76mm MAFS, MP 85mm TB, polished MP plenum, raised blower top, Magnaflow resonator & mufflers, 5% pulley, Double IC & 800 CFM fan, 3.73:1 gears, Trac Lok, SCT chip, TransGo shift kit.
96 4.6 LX
mcate is offline
post #2 of 9 (permalink) Old 09-25-2006, 09:33 AM
The Great Obucina's Avatar
the pressure gauge is an idiot switch. If your oil pump was failing, you would know it quick, fast, and in a hurry.
the terminal is probablyy loose, dirty, or the sensor is going sowf......no biggie.
"Booyah". Stu Scott.
The Great Obucina is offline
post #3 of 9 (permalink) Old 09-25-2006, 10:06 AM
johnaec's Avatar
Are you sure the oil level isn't so low that when it moves to the front with deceleration it might be uncovering the pickup?
John
'96 T-Bird 4.6 LX, SVT Cobra Rs, 245/50R17 BFG Comp T/A, D-chip
johnaec is offline
post #4 of 9 (permalink) Old 09-25-2006, 03:48 PM Thread Starter
No, it's full. It's about time for an oil change, but the level is fine.
96 4.6 LX
mcate is offline
post #5 of 9 (permalink) Old 09-25-2006, 03:56 PM
MattsLE97's Avatar
Send a message via AIM to MattsLE97 Send a message via Yahoo to MattsLE97
http://forums.tccoa.com/showthread.php?t=75977 do this mod it works a heck of alot better
-Matt-
2000 dodge dakota 4.7L 4x4
Flowmaster 3" SI/DO 2.5
31" cooper stt tires (mud and off roading here I come)
MattsLE97 is offline
post #6 of 9 (permalink) Old 09-25-2006, 06:00 PM Thread Starter
Wow, I guess I'd never really noticed the lack of needle movement on any of my T-Birds. Sounds like a good mod to do on both my LX & SC this winter.
96 4.6 LX
mcate is offline
post #7 of 9 (permalink) Old 09-25-2006, 07:34 PM
MattsLE97's Avatar
lol ya after i did it the guage was much more active its not a true oil reading but its closer than whats in there
-Matt-
post #8 of 9 (permalink) Old 10-18-2006, 10:17 AM
97qwikcat's Avatar
instead of staring a new thread, I have a autometer gauge in my car for oil pressure. Well actually it was made for fuel pressure. I hooked it up and tossed my old oil pressure gauge. The autometer was working fine then this morning on the way to work it quit working?!?!?!? Origanally I had a sunpro gauge and it worked fine til I broke the fitting off the sender when putting the block in my truck. What gives why did this gauge quit working??
My mod's
97qwikcat is offline
post #9 of 9 (permalink) Old 11-08-2006, 12:27 AM
TGJ
Baddest N/A NPI in Canada
TGJ's Avatar
Check the wiring.
TGJ is offline
