Bank 1 Too Rich? - TCCoA Forums
post #1 of 6 (permalink) Old 09-29-2006, 08:00 AM Thread Starter
T6Rocket's Avatar
Bank 1 Too Rich?
The GF's 96 Cougar 4.6 with 105k miles has had the check engine light on for a month or two. Car is still running great on 89 octane - no pinging or bucking (finally got rid of that! She claims gas mileage has been fine, but I noticed she only went 170 miles on almost 3/4 tank.
Took it to Autozone and the guy said the code read "PO 172, Bank 1 too rich". Does that sound like an O2 sensor or
Thanks in advance!
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #2 of 6 (permalink) Old 09-29-2006, 11:24 AM
Moderator & Teksid Whore
guitar maestro's Avatar
could be the upper O2, since it is only coming out on one side.....at 105k, its about time to replace both upper O2s.....also clean the maf, then reset the computer by pulling out fuse #15 in the power distribution box, then crank it a couple quick times, then put the fuse back and start it up
guitar maestro is offline
post #3 of 6 (permalink) Old 09-29-2006, 03:23 PM Thread Starter
T6Rocket's Avatar
Thanks for the tips!
Al
Previous Fords:
T6Rocket is offline
post #4 of 6 (permalink) Old 09-29-2006, 06:10 PM
Rolling-Thunder's Avatar
Probably wouldn't hurt to clean the MAF sensor too.
Easiest way is with some MAF sensor spray cleaner, or electronic contact spray cleaner, available at Walmart and local parts stores.
Do a search on the subject for specifics, as it has been talked about alot.
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #5 of 6 (permalink) Old 10-02-2006, 01:53 PM Thread Starter
T6Rocket's Avatar
The MAF wire has been cleaned, it is fine.
Is the left side of the motor considered to be "bank 1"?
Al
Previous Fords:
T6Rocket is offline
post #6 of 6 (permalink) Old 10-02-2006, 06:49 PM
No, passenger side is bank 1, due to cylinder #1 residing there.
