Trunk Insanity - TCCoA Forums
post #1 of 17 (permalink) Old 09-29-2006, 08:28 AM Thread Starter
Trunk Insanity
Now that the hood is closed, Scott has move on to the trunk. Some of these shots have been posted here and there on other threads,
but as it comes together I really thought the trunk deserves its own thread,
so you guys can see it all in one place right up to the finished product.
Here's the driver's side and a bit of the center:
Here's the center at nite (Leds to light up the amp):
Here's a mock up of the passenger side:
On the right is the battery box (the white box in front)
then there is this box behind the battery box
(more about that later & what's inside it):
In that pic, on the left you can also see a bit of the JL subwoofer, which is mounted alongside the amp.
Then there is the red marine switch and grey connector alongside
the boxes in front of the wheel well (I'll let Scott expain):
Originally Posted by Big Scott
The red dial is used to switch between the normal power path and the remote on/off switch located in a spare tailight that can be quickly hooked up via the fat *** grey connector. The remote switch is needed since the battery is located in trunk. Figured it was a pretty cool idea and another example of the "Trunk wiring" I have to finish before SSHS#6....I'll be in the bathroom when this car screams down the track :leave: .
-Scott
Before all that, Scott drilled a hole through the trunk floor
and fashioned a mounting plate:
Finished it off:
and installed some hardware:
Can anyone guess what that is for??
Does this help?
How about this:
More will be revealed.
-mike
96 GoldBird
N/A:
96 GoldBird is offline
post #2 of 17 (permalink) Old 09-29-2006, 08:29 AM Thread Starter
And from the inside out:
-mike
post #3 of 17 (permalink) Old 09-29-2006, 10:03 AM
Traveler's Avatar
Well, if thats an aftercooler, and it uses Ice as I've read then I'd say that the ice melts, and the water has to be drained somehow.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #4 of 17 (permalink) Old 09-29-2006, 10:07 AM
TSTaCC President
Bob Kinee's Avatar
Send a message via AIM to Bob Kinee Send a message via MSN to Bob Kinee Send a message via Yahoo to Bob Kinee Send a message via Skype™ to Bob Kinee
The water is very easily drained from those. Its just a purge valve system. My godfather ran an ice system in his camaro and its not too hard.
Kudos on the trunk though...Custom doesn't come in a box. You got a lot of things going on all at once there. I don't envy the stress levels you are probably enduring.
(2)93 lx 5.0s BOTH sunrise red
Double the pinkiness!
President of the Tri-State ThunderBird and Cougar Club
www.TSTaCC.com
Bob Kinee is offline
post #5 of 17 (permalink) Old 09-29-2006, 10:21 AM Thread Starter
That's half the function. There is a drain line from the cool can attached so I can drain the melted ice from the can.
The main line from the Intercooler coolant pump is also attached so that we can pump/drain coolant from the main system. Ice can also be introduced directly into the reservoir when racing. You gotta drain coolant to make room for the ice to go in. Afterward when it melts, water can be drained off and coolant added back for everyday driving. And, of course, just like the engine collant system, from time to time the intercooler system needs to be drained and flushed and refilled.
I'm just trying to figure out whether I want to use ice made with distilled water and just let it melt into the coolant, or use those little plastic ice cubes that are re-usable and just fish them out of the reservoir when I'm done. Or maybe just one of those frozen plastic ice thingys from a small (six pack size) Igloo lunch box cooler.
-mike
post #6 of 17 (permalink) Old 09-29-2006, 10:52 AM
TSTaCC President
Bob Kinee's Avatar
Ice is ice....use some cubes or just buy a $2 bad of ice and bring some sandwhich baggies.
www.TSTaCC.com
post #7 of 17 (permalink) Old 09-29-2006, 11:03 AM
Eleventeenth Gear Poster
Aaron K.'s Avatar
Those little plastic ice cubes suck...I say just use regular old ice.
When are you gonna post pics of the glovebox?!?!?
Sold = 96 Thunderbird
Aaron K. is offline
post #8 of 17 (permalink) Old 09-29-2006, 11:11 AM Thread Starter
Originally Posted by Bob Kinee
Ice is ice ........
Not really... Do you put regular tap water in your radiator?
Should use distilled water.
Any ice cubes that go in that intercooler system will be distilled, or encased in plastic. Trust me.
-mike
post #9 of 17 (permalink) Old 09-29-2006, 02:27 PM
02 Explorer Pioneer
timb's Avatar
-mike
Common Mike go for the gold....call up TriGas and get a dewar of liquid Nitrogen
Birdless
timb is offline
post #10 of 17 (permalink) Old 09-29-2006, 03:13 PM Thread Starter
Well, I thought about dry ice.. but the smoke coming out of the trunk might not be appreciated..
Are you in GA yet? If you are, you oughtta take a couple of hours and visit Scott... She is a whole different animal in person.. your eyes just don't know where to focus next...
He told me I oughtta start planning on coming up soon, for a test drive. I can't this weekend, or next weekend, but I may be up the following weekend. That would be 10/14 - 10/16... Then back again for SSHS 6 in November (I hope).
Who knows if she's ready to come home, I'll bring a buddy up with me in the vette, and one of us will drive GB home, the other, the vette.
any volunteers??
-mike
post #11 of 17 (permalink) Old 09-29-2006, 03:18 PM
02 Explorer Pioneer
timb's Avatar
Yes we have moved up but I am still commuting back to Ft Lauderdale every other week. I am driving the bird back to GA this weekend because my FL plates are going to expire in OCT. I brought the family down and will be taking them to Disney on the way up. I will be in town the 14th - 16th so feel free to stay at our place if you need a room we have plenty to spare. I am about 40 minutes from the airport.
Birdless
timb is offline
post #12 of 17 (permalink) Old 09-29-2006, 04:01 PM Thread Starter
Heck if your still commuting in November, maybe you can drive something back to FL... and I'll sky miles you back...
I'll let you know when I'll be coming up..
-mike
post #13 of 17 (permalink) Old 09-29-2006, 10:29 PM
Overkill Fetish Freak
Dr. FrankenCougie is offline
post #14 of 17 (permalink) Old 09-30-2006, 12:02 AM
TSTaCC President
Bob Kinee's Avatar
-mike
My bad. I was thinking you were using a different system. The one I used was a coffee can style with the coiled tube in the center and we would put bags of ice in the center. Old school way of cooling thins down.
www.TSTaCC.com
post #15 of 17 (permalink) Old 10-04-2006, 11:49 PM
-Scott
post #16 of 17 (permalink) Old 10-08-2006, 02:30 AM
The small switch is for the LED over ride.
The ground hooks up to a bolt welded to the frame.
-Scott
post #17 of 17 (permalink) Old 10-08-2006, 09:18 AM
And i thought the connector (right of the battery select switch) was gonna be used for Jump starting the car if need be neat use of it thou i do say
Looking not too baddly.. the trunk looks too `busy' to me, but then again, there's one hell of alot of things happening back there...
91 XR7 is offline
