PI Intake Swap... not the normal question - TCCoA Forums
post #1 of 11 (permalink) Old 09-29-2006, 01:12 PM Thread Starter
Now that I just snarfed this intake on eBay, I have a quick question about the sealing of the water port.
http://cgi.ebay.com/ebaymotors/ws/eB...m=250032284555
I'm going to use the rtv method, but since this intake has the gaskets built into it, do I just rtv the proper area, or do I remove the gaskets on the intake and use the stand alone gaskets?
Oh, it's going on my mom's 96 Grand Marquis which still has the plastic intake and for the price couldn't pass it up.
69 F100 LWB w/460 Engine
post #2 of 11 (permalink) Old 09-29-2006, 01:24 PM
ThunderB's Avatar
Good score. Wonder how well it works with the built-in gaskets? Might make it simpler to install if there's no locating pins. No need to worry about the gaskets skewing on installation. I'd try it with the built-in gaskets.
Do the built in gaskets peel off?
97 T-Bird Sport: Dynomax catback, Removed silencer w/ K&N panel, DReinhart chip, Lightning AGSF12-FM1 plugs/180 stat, Tokico 1.25" dropped stance, bye bye fender gap
'79 F100 SB : 300 ci six, Hurst Mastershift 3spd floor shifter, Offenhauser intake, Holley 4 brrl, EFI manifolds, Chebbie Rockers, Summit Racing 3.50 gearset, DISO 2.5" diesel muffler and 2.5" exhaust, Its'a six?!
ThunderB is offline
post #3 of 11 (permalink) Old 09-29-2006, 01:26 PM
95xbird's Avatar
Here's a thought.Put it on the bird!Good deal though.
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #4 of 11 (permalink) Old 09-29-2006, 01:28 PM
The Great Obucina's Avatar
that is more than likely the doorman manifold.
"Booyah". Stu Scott.
The Great Obucina is offline
post #5 of 11 (permalink) Old 09-29-2006, 01:31 PM Thread Starter
Is that a good or bad thing? I didn't do a lot of research on the pro's con's of the different intakes since this was $40.
post #6 of 11 (permalink) Old 09-29-2006, 01:33 PM
it may be more difficult to do the manifold swap with that integrated gasket thing.....
post #7 of 11 (permalink) Old 09-29-2006, 01:44 PM Thread Starter
I was thinking that before I bid on it. I've ordered a set of gaskets so I'll do an analysis when I have everything sitting on a table (I have a set of NPI heads available). What I'm hoping is that the integrated gasket things can be removed, and then the OEM gaskets be installed and they line up with the grooves in the intake (assuming there are grooves!!)
We shall see.
post #8 of 11 (permalink) Old 09-29-2006, 03:47 PM
MattsLE97's Avatar
Send a message via AIM to MattsLE97 Send a message via Yahoo to MattsLE97
I would think you would be fine even with those in there. All your doing is putting a dab of rtv on the front water port the passenger and dab on the rear drivers side and enough that it squishes out some to see it properly. You should be fine with that
-Matt-
2000 dodge dakota 4.7L 4x4
Flowmaster 3" SI/DO 2.5
31" cooper stt tires (mud and off roading here I come)
MattsLE97 is offline
post #9 of 11 (permalink) Old 09-30-2006, 06:46 PM
3rd Gear Chirper
hotbird's Avatar
I have that manifold (mine is PI style, for an 02 4.6), and I left the built-in gaskets in place and just added orange RTV at the coolant ports and slapped it on there. On my PI manifold there are recessed areas right by the ports, so I filled those with RTV then proceeded to add RTV in the usual manner. It works great, and yes the gaskets (actually o-rings) do come off if you wish.
hotbird is offline
post #10 of 11 (permalink) Old 10-06-2006, 10:40 PM
kraken2026's Avatar
Send a message via AIM to kraken2026 Send a message via Yahoo to kraken2026
Hey guys I'm just gonna take a wild stab in the dark and guess these intakes won't work on our cars right? http://cgi.ebay.com/ebaymotors/2005-...QQcmdZViewItem
-94 T-bird 4.6L SOHC "Driver"
Full Pioneer sound system, 3rd muffler delete, PBR front Calipers, Rear disc conversion, Strut Tower Brace, Marauder Torque converter, True CAI & Silencer removal w K&N.
Planned upgrades: SC trac-loc pumpkin, Magnaflow SS mufflers & SS resonator tips, SC ground effects.
-93 Eddie Bauer Bronco
5.0L, E4OD, FatBob 2" Suspension lift, K&N CA, 2-1/2" flowmaster exhaust, sixliter ignition, 96 EB interior, Alcoa rims with 33's.
-92 Firebird 5.0 TBI, 4L60 "Project"
Accel / Holly Annihilator ignition, Dynomax cat back, adj. panhard Bar & T/A Sways, Formula 17x8 Rims, LT1 4L60 conversion, rear disc w posi conversion.
What can I say, birds of a feather flock together
kraken2026 is offline
post #11 of 11 (permalink) Old 10-06-2006, 10:49 PM
Tx_Cat's Avatar
Nop
Tx_Cat is offline
