pulling motor ? - TCCoA Forums
post #1 of 2 (permalink) Old 10-01-2006, 09:47 AM Thread Starter
pulling motor ?
was wondering if the wire running to the starter is bolted to thye motor?if so how do ya remove it?do ya have to pull the starter?
shelbyseven is offline
post #2 of 2 (permalink) Old 10-01-2006, 10:33 AM
Awaiting E-Mail Confirmation
tinman_72's Avatar
IIRC, it is bolted where it goes between the motor and mount and also at the bottom of the timing cover on the passenger side. When you lift the motor a little you should have enough room to get to the one behind the mount.
tinman_72 is offline
