Which water pump? - TCCoA Forums
post #1 of 11 (permalink) Old 10-02-2006, 07:57 AM Thread Starter
JR Tigerstar's Avatar
Which water pump?
I think my original water pump is going out on me.
The coolant level in the reservoir goes down every few days &
while I have not noticed/seen any leaks while the car is parked, I have smelled coolant.
I believe the water pump might be leaking the coolant from the "weep" hole.
Which water pump should I get?
Cobra? Bullitt? GT? Evans?
I have Windsor PI cylinder heads on the stock Romeo shortblock & '96 timing cover.
JR Tigerstar is offline
post #2 of 11 (permalink) Old 10-02-2006, 08:10 AM
basskid's Avatar
Send a message via AIM to basskid
I had to make the same call on my 96 grand marquis. I ended up going with the stock pump. From my understanding, the cobra pump was deisgned to help prevent cavitation at high engine rpm. The stock pump for my engine was designed to provide more flow at idle, ie for idling squad cars. Seeing as how my marquis ideld a bit more than running at high rpms, I went stock with no problems.
basskid is offline
post #3 of 11 (permalink) Old 10-02-2006, 08:22 AM
Refrigerator Raider Hater
GreenBird's Avatar
For a ford pump, you want the long shaft, closed vane (early cobra, 99-mid-01 GT pump. You'll want the long pump to keep your current pump pulley. The closed vane pump is more efficient.
As for the Evan's pump, JL apparently uses one and has recommended it to a number of people. Kinda expensive though, I found a price of $170 (about 2.5 times more than a stock pump).
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #4 of 11 (permalink) Old 10-02-2006, 06:31 PM
The Meziere electric pump is yet another option, but it isn't super cheap. I'm very happy with mine.
-Rod
post #5 of 11 (permalink) Old 10-02-2006, 08:38 PM
David_viny's Avatar
Yea, my pump is going out as well. So how many and what are the choices for stock ford pumps?
1995 T-bird 4.6l - Eibach lowering springs, Cobra R hood, One 12" sub woofer, Alpine type-R front speakers. 16.249 @85.11mph 1/4 mile
2001 Pontiac Trans Am WS6 - Cam, headers, HPtuned by me.
David_viny is offline
post #6 of 11 (permalink) Old 10-02-2006, 09:09 PM
The Great Obucina's Avatar
everything 4.6 now is a closed vane pump. Even the explorer. If you want to save money, I new one from autozone is only 40$. OEM is about twice that....
"Booyah". Stu Scott.
The Great Obucina is offline
post #7 of 11 (permalink) Old 10-02-2006, 09:09 PM
huhhuhuhuuh you said long shaft.
post #8 of 11 (permalink) Old 10-03-2006, 12:18 AM
GreenBird's Avatar
there are at least three, but you only care about one. Get one for a 99-00 GT. Maybe the price has gone up, but this spring I paid $65 for a brand new ford pump.
96 Alpine Green V8
post #9 of 11 (permalink) Old 10-03-2006, 10:24 PM
Peter M's Avatar
Ditto here.
The temp holds rock solid no mater where I go, or how I drive. Because it's not engine driven, there's no chance of cavitation. Just a nice, constant flow rate.
Peter M
SOLD 1996 4.6l Thunderbird-(fast) PI intake, custom exhaust, Bullet-Resistant Tranny™, blah, blah, blah
2007 VW GTI-(faster) United Grey, 18" wheels, APR stage 1 chip, and... uh... that's it for now.
________________________
..this space for rent..
Peter M is offline
post #10 of 11 (permalink) Old 10-06-2006, 07:49 PM
High-Mileage 4.6L Thrasher
Johnny Langton's Avatar
I actually use the '99GT pump with the closed impeller.Might be switching to a Meizere electric in the future though.
JL
Fuelly
Johnny Langton is offline
post #11 of 11 (permalink) Old 10-06-2006, 08:53 PM
mercoug302's Avatar
JL
I also have one in my 96 Mark, nice pice. Definetly a noticable difference.
1988 XR7
5.8L EFI, tremec 3550,spec stage III clutch,90mm L-MAF, TFS heads, GT40 intake, lunati cam,Fordchip.com,diablo chip 311rwhp 375 rwft/lbs.13.2 @107.2. with 3.08's
2004 Pontiac GTO LS1 6 speed black/red RIP
mercoug302 is offline
