misfires when gave full throttle - TCCoA Forums
post #1 of 10 (permalink) Old 10-02-2006, 11:12 AM Thread Starter
Unhappy misfires when gave full throttle
hello everyone I have a 95 thunderbird with a 4.6L and when i go to pass a car i hear a alot of poping in the exhust its got ture duels on it it sounds like a major backfireing problem can anyone help me?
biggin002 is offline
post #2 of 10 (permalink) Old 10-02-2006, 11:15 AM
leet sauce
eg0r's Avatar
1. search
2. replacing spark pluges/spark fires/fuel filter/cleaning maf ? done any of that?
eg0r is offline
post #3 of 10 (permalink) Old 10-02-2006, 12:15 PM Thread Starter
i have done all but cleaning the maf how would i go baout doing that like what wolud i use to clean it
post #4 of 10 (permalink) Old 10-02-2006, 12:22 PM
Faster than Porkchop
cjchevez's Avatar
Check the tech articles on the main page .
Go to intake ,down at the bottom you will see cleaning MAF wires .
You can use search also .
1997 Ford Thunderbird 4.6 Sport .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
PI heads *PI intake*Mark VIII torque converter*Cobra T-loc w\4.10's * Jmod*tranny fluid cooler*P&P stock T/B & plenum*UD pulleys* Dynotech 4in ds*80mm Lightning maf*Xcal2*02 GT intake tube.
cjchevez is offline
post #5 of 10 (permalink) Old 10-02-2006, 12:24 PM
David_viny's Avatar
I just did this about 2 days ago. It’s VERY simple, but you will need a tamper proof T-20 torx bit. If you can’t find one (I had a fairly difficult time getting one), U can cut a slot in the screw to make a flathead screwdriver work. AutoZone has these bits BTW.
I used window cleaner, it was mentioned somewhere on the forum. Basically, you want a cleaner that doesn’t leave any residue when dry and isn’t too harsh on the sensor element.
1995 T-bird 4.6l - Eibach lowering springs, Cobra R hood, One 12" sub woofer, Alpine type-R front speakers. 16.249 @85.11mph 1/4 mile
2001 Pontiac Trans Am WS6 - Cam, headers, HPtuned by me.
David_viny is offline
post #6 of 10 (permalink) Old 10-02-2006, 12:24 PM
leet sauce
eg0r's Avatar
eg0r is offline
post #7 of 10 (permalink) Old 10-02-2006, 12:28 PM
leet sauce
eg0r's Avatar
btw do you have cats? if so are they stock/highflow?
CEL light on/off?
eg0r is offline
post #8 of 10 (permalink) Old 10-02-2006, 01:47 PM Thread Starter
well I cleaned my maf sensor and if car runs better than ever thanks everyone!
post #9 of 10 (permalink) Old 10-03-2006, 03:51 AM
hell yeah, just as egOr and I have noted in a different thread---the maf clean makes major change.....I got 30-40 % more power when I had initially thought the engine was on its last legs(backfiring, valve rattles, bogged when I would floor it). Glad it is fixed for you now
95Tbirder is offline
post #10 of 10 (permalink) Old 10-06-2006, 10:15 PM
kraken2026's Avatar
Send a message via AIM to kraken2026 Send a message via Yahoo to kraken2026
I've been noticing it can even make some trans act like they are giving up weird how that seems to be kind of a cure all for these cars huh.
-94 T-bird 4.6L SOHC "Driver"
Full Pioneer sound system, 3rd muffler delete, PBR front Calipers, Rear disc conversion, Strut Tower Brace, Marauder Torque converter, True CAI & Silencer removal w K&N.
Planned upgrades: SC trac-loc pumpkin, Magnaflow SS mufflers & SS resonator tips, SC ground effects.
-93 Eddie Bauer Bronco
5.0L, E4OD, FatBob 2" Suspension lift, K&N CA, 2-1/2" flowmaster exhaust, sixliter ignition, 96 EB interior, Alcoa rims with 33's.
-92 Firebird 5.0 TBI, 4L60 "Project"
Accel / Holly Annihilator ignition, Dynomax cat back, adj. panhard Bar & T/A Sways, Formula 17x8 Rims, LT1 4L60 conversion, rear disc w posi conversion.
What can I say, birds of a feather flock together
kraken2026 is offline
