Choice for New Engine - TCCoA Forums
post #1 of 14 (permalink) Old 10-03-2006, 02:14 AM Thread Starter
TBirdsRMachismo's Avatar
Send a message via AIM to TBirdsRMachismo
So next summer once I have some more cash I wanna dump some g's into the car. With 160,xxx almost at this point, modding the engine seems like a waste. Now I wanna just buy a new engine. Would it be better to get a Mark 8 DOHC engine, or a PI engine? Now a difference of a thousand dollars isn't the issue, I'm looking for best performance and what can be modded more easily.
96' 4.6l LX Sport - Modding put on hold for awhile
91' Chevy 1500 - Can't wait for the 383 Stroker
TBirdsRMachismo is offline
post #2 of 14 (permalink) Old 10-03-2006, 02:23 AM
twin turbo 281's Avatar
i would like to see someone drop in a 3V motor theres actually alot of good ones circulating around because of 05-06 GT owners swaping the 3Vs out for the DOHC there performance is close to a DOHC and they are a very efficient setup...you would get great gas milage with the VVT!!
twin turbo 281 is offline
post #3 of 14 (permalink) Old 10-03-2006, 03:13 AM
BIG PETE's Avatar
I have no idea if the VVT is even an option with our factory EEC's, it would probably require a total harness hack job. The 3v head isn't bad, but I would not want that thing for any application that would see boost, that one exhaust valve is poised to go up in smoke.
I would say that no matter what head you go with, a big bore block is the way to go. Obviously, 32v has the most potential, but eventually any head work will cost a small fortune with all those valves, runners, retainers, cams, and springs. But, which is the best really depends on how much you'd ultimately like to spend and what your goals are, since the best totally depends on what you're looking for.
Pete
-97 XR-7
-5.0 Big Bore ...
Density Altitude = 4132'
1/8 mile: 8.75 @ 82
BIG PETE is offline
post #4 of 14 (permalink) Old 10-03-2006, 04:01 AM
VVT is variable valve timing it rotates the cam profile a few degrees to help promote minimal valve overlap for great torque and open up the overlap for better higher rpm power..they do respond to boost just fine but the stock computer system on the new GTS is very sensitive and it would be better ran with an aftermarket programable ECM. just and i dea Im sure someone will do the swap in these cars someday if they havent already?
2x95 cougars to the scapper
51 Mack A51T restoration
post #5 of 14 (permalink) Old 10-03-2006, 06:20 PM
TGJ
Baddest N/A NPI in Canada
TGJ's Avatar
There is no way to adapt the 3V motor to the MN12 EEC and use the VVT from the 3V motor. Fitting the 3V motor under a hood on the MN12 is no easy task either, I seriously doubt it will fit under the aftermarket hoods available. This is due to the front air entry on the intake Manifold from the 3V motor.
Personally, I would get the Mark VIII motor, do a Big-Bore to it. Choose either a good set of ported 2V heads or good 4V heads( 99 +4V or FRPP 4V heads ). But what do I know...
TGJ is offline
post #6 of 14 (permalink) Old 10-03-2006, 07:15 PM
I'd go with a BB DOHC as well if you can afford it.
Originally Posted by twin turbo 281
custom low budget twin turbo 281 with comp cams and many other bolt ons!
Pics???
-Rod
post #7 of 14 (permalink) Old 10-03-2006, 07:40 PM
17Mark71's Avatar
If money is tight, an aluminum '02+ Explorer engine would be good. Throw a set of P and P'd heads and some cams (VT, Comp, SHM....).
'97 Sport Option'd T-Bird
DSS Shortblock, PI Heads, 262AH Cams, Kooks, SVO SC with stock pulley,
42 lb injectors, 70mm TB, '02 GT MAF, Vogtland Springs, Mk VIII DS,
Marauder TC, 17" SVT T-Bird Rims, Michelin PS2 235/50/17, True Duals,
4.10 gears, J-modded tranny
300RWHP 335RWTQ
Member of www.midwestthundercats.com
17Mark71 is offline
post #8 of 14 (permalink) Old 10-04-2006, 01:03 AM
The Great Obucina's Avatar
02 exploder.....and cam it. Crower 2 is a good choice.
"Booyah". Stu Scott.
The Great Obucina is offline
post #9 of 14 (permalink) Old 10-04-2006, 12:27 PM
David_viny's Avatar
If you have the money, the late 90's cobra motor would be awsome. It has a great built bottem end, heads are good and the rpm limit can be cranked up to 7,000rpm. Those motors at 7,000rpm sound sooo awsome.
1995 T-bird 4.6l - Eibach lowering springs, Cobra R hood, One 12" sub woofer, Alpine type-R front speakers. 16.249 @85.11mph 1/4 mile
2001 Pontiac Trans Am WS6 - Cam, headers, HPtuned by me.
David_viny is offline
post #10 of 14 (permalink) Old 10-04-2006, 12:28 PM
too bad that arent that fast.
post #11 of 14 (permalink) Old 10-04-2006, 02:05 PM
JustinH's Avatar
the aluminum 4.6 motors are getting tougher to find guys.
They aren't making em anymore
When there was a ton of smashed suv's that motor used to be 900 bucks.
Not any more
JustinH is offline
post #12 of 14 (permalink) Old 10-04-2006, 08:48 PM
David_viny's Avatar
Faster then a PI
post #13 of 14 (permalink) Old 10-05-2006, 12:15 AM
Faster then a PI
the car in the left lane was just over 3 tenths quicker and 500 lbs lighter than me on my only run with the PI. Joe wasnt impressed. For our cars, they really seem to need short gears and a high stall to really take advantage of the lack of torque the 4v exhibits down low.
post #14 of 14 (permalink) Old 10-05-2006, 02:12 AM Thread Starter
What kind of numbers can one see from a cammed 02 exploder engine?
