Machining NPI Heads while on the block - TCCoA Forums
post #1 of 11 (permalink) Old 10-05-2006, 05:20 PM Thread Starter
Traveler's Avatar
Anyone have any thoughts about how this guy port matched his heads to the PI intake? Safe? Foolish?
http://www.cardomain.com/ride/558234/3
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #2 of 11 (permalink) Old 10-05-2006, 06:34 PM
Like Titles Matter
kdanner's Avatar
Hackjob, waste of time. I've also never seen an Explorer intake like that, only seen those intakes on trucks and vans, Explorer looks like a car intake.
1998 GT - [email protected]
generated by sloganizer.net
kdanner is offline
post #3 of 11 (permalink) Old 10-05-2006, 06:38 PM Thread Starter
Traveler's Avatar
Yea, I was wondering about that intake to. I was more curious about working ont he heads while they were on the car. Think the tape and grease would keep the shavings out?
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #4 of 11 (permalink) Old 10-05-2006, 08:33 PM
my cousin dave ports and polshes heads and intakes while on cars. he stuffs the cylnders with duct tape shaped like a funel then stuffs it with fine steel wool. No problems. But machining is someting else... bad choice
2011 Kia Sorrento
1996 T-bird
*SOLD* 2007 Suzuki M50
Looking for a new ride!
funderbird is offline
post #5 of 11 (permalink) Old 10-05-2006, 08:37 PM Thread Starter
Traveler's Avatar
Ok, I might have mistakenly used the words "machining" and "porting/polishing" interchangebly. Is what this guy did relatively safe?
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #6 of 11 (permalink) Old 10-05-2006, 08:38 PM
Silenced's Avatar
Can someone tell me a little bit more about that type of intake?
Silenced is offline
post #7 of 11 (permalink) Old 10-05-2006, 08:39 PM Thread Starter
Traveler's Avatar
It looks like one of the intakes used on the trucks and vans. might work on a Thunderbird, if you like either holes in your hood or one big a** cowl.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #8 of 11 (permalink) Old 10-06-2006, 12:26 AM
Refrigerator Raider Hater
GreenBird's Avatar
Port matching is worth very little on a stock-ish motor. In fact, because it opens up the port it's possible to LOSE power. Also, the mismatch between NPI and PI heads is hardly noticeable.
Here are two examples. The NPI port is on the head, the PI on the intake. Both have been worked, but notice they didn't open it up to the edge of the gasket.
As for the coolant port, that is something I would do if I knew someone who welds aluminum.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #9 of 11 (permalink) Old 10-06-2006, 12:46 AM
Fry Rice Specialist
Casper's Avatar
they way he do it i would only do it with a vacumm next to it to suck it up and the duct tape stuff act as a secondary precaution.
CarDomain Page
Casper is offline
post #10 of 11 (permalink) Old 10-06-2006, 12:48 AM Thread Starter
Traveler's Avatar
Thats not a bad idea either.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #11 of 11 (permalink) Old 10-06-2006, 07:52 AM
nickmckinney's Avatar
I would say you could do it with the cams removed so all the valves are closed, then vacuum out what was left behind. However anyone that port matches to the gasket especially the PI gasket since it is so oversize has no clue how much worse their velocity probably is. The best intake port is usually a smooth taper down from the plenum to the bowl and you have to think of the intake manifold as an extension of the head. From what I saw in those pictures it looks like he made 2 bell mouthed junctions at the gasket which when bolted together is a big bubble area inside of a tube (bad for flow in the tube) A generic "gasket match" is probably the most common mistake by newb home porters I imagine especially since the magazines spout it so much.
BTW - You need to work the bowl of that head also to increase the flow, what he did didn't change the flow in the head I would imagine since that isn't where all the restriction is.
nickmckinney is offline
