Modular truck motor question. - TCCoA Forums
post #1 of 9 (permalink) Old 10-06-2006, 11:21 AM Thread Starter
JustinH's Avatar
Got a customer with a 99 expedition.
He needs a 4.6 motor.
The interchange comes up asking me if the engine has a 6 or 8 bolt flywheel.
Two questions...
Does it matter which engine he gets? Can't he just reuse his old flywheel if he gets one with the wrong flywheel?
How would one tell how many bolts are on his flywheel without physically yanking the motor?
Thanks guys.
Justin
JustinH is offline
post #2 of 9 (permalink) Old 10-06-2006, 11:46 AM
Moderator & Teksid Whore
guitar maestro's Avatar
as per my FRPP catalog,
"4.6L engines may have 6 or 8 bolts to attach to the crankshaft. CHeck the engine code before ordering. Romeo built engines have 6 bolts and Windsor built engines have 8 bolts. All Cobra engines have 8 bolts. The 8th character in the Vin ix (X) for Windsor engine plant, or (W) for Romeo engine plant."
so it would matter which engine he gets, since if his is a Windor (8-bolt) and you give him a Romeo (6-bolt) and the Romeo's TC bolt pattern does not match his TC, then he can't use his old flywheel since it wont bolt up to the different crank
hope this helps
guitar maestro is offline
post #3 of 9 (permalink) Old 10-06-2006, 12:36 PM
Darrin's Avatar
The torque converter pattern is the same. The ony difference is the number of bolts that hold the flexplate on. If it has an automatic, and I assume it does, then its probably a 6 bolt. If you get the wrong bolt count on the engine you get you can just get a 6 bolt flexplate.
What does the vin number for the vehicle say the engine is?
Darrin
Darrin is offline
post #4 of 9 (permalink) Old 10-06-2006, 12:43 PM Thread Starter
JustinH's Avatar
Its a 99 expedition..
1FMRU1861XLA30378
JustinH is offline
post #5 of 9 (permalink) Old 10-06-2006, 12:46 PM
fast Ed's Avatar
Justin, when I look up a replacement crankshaft for a 99 Expedition 4.6, the service replacements only come in 8 bolt. It states that if the vehicle has a 6 bolt flywheel, than the flywheel has to be changed.
So I'd say that's your answer ... if you get another engine with the wrong bolt count, just change the flywheel too.
cheers
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #6 of 9 (permalink) Old 10-06-2006, 01:02 PM
rjstat's Avatar
Send a message via AIM to rjstat
1FMRU1861XLA30378
Your motor is from the Windsor plant the X after the 1 is the engine assy plant code.
97 - 4.6L Alpine Green Cougar XR-7 w/ Fiber Concepts Hood, SPC cold air intake, 2.5 SLP Dual Exhaust, Eclipse CD4000 w/ Polk's speakers, Koni Shocks, 11/4" Addco sway bars, and Vogtland more to come.
05 - 5.4L Black Eddie Bauer Expedition loaded
rjstat is offline
post #7 of 9 (permalink) Old 10-06-2006, 01:07 PM Thread Starter
JustinH's Avatar
Thanks gents that answers my question.
Just for the sake of future reference, heres what the interchange looks like for a 99 expedition.
8-280 (4.6L), VIN code 6 (Windsor), 6 bolt flywheel
8-280 (4.6L), VIN code 6 (Windsor), 8 bolt flywheel
8-330 (5.4L SOHC, VIN L)
8-280 (4.6L), VIN code W (Romeo)
JustinH is offline
post #8 of 9 (permalink) Old 11-22-2006, 05:12 PM
Nope. The X in that VIN is the 10th digit which represents the year. 1999 in this case.
http://images19.fotki.com/v358/photo...Tbird01-vi.jpg
1994 White (WT) TBird - 4.6 L SOHC with 4R70W
"Sir, if you were my husband, I would poison your drink."
-Lady Astor to Winston Churchill
"Madam, if you were my wife, I would drink it."
-His reply
Rehab progress link
Today's Progress
DScruggs is offline
post #9 of 9 (permalink) Old 11-25-2006, 09:05 AM
Just to put my month old response in..
Print This Page
VIN Results New Search
VIN: 1FMRU1861XLA30378
World Manufacturer Identifier - 1st, 2nd, 3rd Positions
VIN Code: 1FM
Assembly Country: USA
Make: Ford
Body Style: Sport Utility
Restraint System Type (Passenger Cars) or Brake Type and GVWR Class (Trucks and Vans) - 4th Position
VIN Code: R
Restraint: AIRBAG, SECOND GENERATION
GVWR Range: 6,001 - 7,000 Pounds
Line,Series Body Type - 5th, 6th, 7th Positions
VIN Code: U18
Vehicle Line: Expedition
Vehicle Type: Truck/SUV
Engine Type - 8th Position
VIN Code: 6
Engine: 4.6 L
Cylinders: 8
Fuel: Gasoline
Engine Manufacturer: FORD - WINDSOR ENGINE PLANT
Horsepower: 240 HORSEPOWER
Model Year - 10th Position
VIN Code: X
Model Year: 1999
Assembly Plant - 11th Position
VIN Code: L
Assembly Plant: MICHIGAN TRUCK: WAYNE, MI
Production Sequence Number - 12th - 17th
VIN Code: A30378
Prod Sequence Number A30378
New Search
Beast of Bird'n is offline
