C&L issue - TCCoA Forums
post #1 of 8 (permalink) Old 10-06-2006, 11:49 AM Thread Starter
97qwikcat's Avatar
C&L issue
Hey guy's I know some of you have the C&L plenums. Have you guy's had any problem's with the throttle body not opening all the way? With mine I have no clue why but the cable feel's loose and in order to get to WOT I practically have to be standing on the pedal. Any help is greatly appreciated. I want to get this fixed before I park it for the winter.
My mod's
97qwikcat is offline
post #2 of 8 (permalink) Old 10-06-2006, 01:03 PM
Moderator & Teksid Whore
guitar maestro's Avatar
no problems here....i have the Accufab 75mm TB....which one do you have?
have you pulled off the intake tube and turned the TB/pulled the cable manually to see whats going on?
guitar maestro is offline
post #3 of 8 (permalink) Old 10-06-2006, 01:20 PM Thread Starter
97qwikcat's Avatar
yeah if I pull it manually it opes fine. but when it's all hooked up and a step on the gas I really need to stand on it. I don't understand it. I bought the tb off a guy on here im not sure which kind it is.
My mod's
post #4 of 8 (permalink) Old 10-06-2006, 03:21 PM
well get someone to push the pedal down while you look inside the TB and around the linkage to see whats going on
post #5 of 8 (permalink) Old 10-07-2006, 04:59 AM Thread Starter
97qwikcat's Avatar
I did that yesterday and I just couldn't see where the problem is. It will go to WOT when my foot is jammed to the floor. Is that the way it is suppose to be?
My mod's
post #6 of 8 (permalink) Old 10-07-2006, 09:33 AM
Fry Rice Specialist
Casper's Avatar
can you adjust the throttle cable to tighten it up? that's what i did to mine.
CarDomain Page
Casper is offline
post #7 of 8 (permalink) Old 10-07-2006, 10:24 AM Thread Starter
97qwikcat's Avatar
the only way that I see to tighten it up is to move the bracket back some which that won't work unless I fab a new bracket with different mod's for it. How did you adjust your's?
My mod's
post #8 of 8 (permalink) Old 10-09-2006, 06:23 AM Thread Starter
97qwikcat's Avatar
Ok I think I got it I took my gas pedal off and put a bracket behind the plate for the pedal then bolted it back up and wham full throttle and im not on the floor.
My mod's
