Arcing between spark plug wires?? - TCCoA Forums
post #1 of 7 (permalink) Old 10-06-2006, 10:20 PM Thread Starter
DirtyBird46's Avatar
Send a message via AIM to DirtyBird46
I put new wires on 25k ago and they are starting to arc between the wires already? I properly routed them and have not touched them since they were installed. Are the wires the only source of this problem or could there be other causes?
Jim
DirtyBird46 is offline
post #2 of 7 (permalink) Old 10-06-2006, 11:02 PM
Whining Intakes Rock
Al_Florida's Avatar
Probably the wires. What brand did you use?
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #3 of 7 (permalink) Old 10-06-2006, 11:13 PM Thread Starter
Stock Ford 8mm wires. If that is the case, that is pretty disappointing considering I got over 100K out of the previous set.
post #4 of 7 (permalink) Old 10-07-2006, 12:41 AM
Are all the wires arcing or just a couple? The OEM wires are pretty good wires, but it's possible that you might have gotten a couple bad ones. They weren't rubbing against anything?
post #5 of 7 (permalink) Old 10-07-2006, 10:42 AM Thread Starter
No rubbing. There is a arc between one wire and the coil bracket and the two wires that run ontop of the DS valvecover are also arcing.
post #6 of 7 (permalink) Old 10-07-2006, 10:42 AM
MattsLE97's Avatar
Send a message via AIM to MattsLE97 Send a message via Yahoo to MattsLE97
I had this exact problem b4 i sold my bird. All 4 wires were arching and i had oem motorcraft ones with far less than 25k maybe 8k at most. Is it arching by the wires that are routed under the alternator??? If so i figured it was either heat or them rubbing. Reroute some new ones over the top of the alternator and put some of that flexible plastic perfurated tubing for wires just to protect them
-Matt-
2000 dodge dakota 4.7L 4x4
Flowmaster 3" SI/DO 2.5
31" cooper stt tires (mud and off roading here I come)
MattsLE97 is offline
post #7 of 7 (permalink) Old 10-07-2006, 10:50 AM Thread Starter
I have not inspected the wires under the alternator, but they are covered with the plastic wire looms you are talking about. Oh well, I am just going to order some new wires and be done with it. I need to get it running so I can finaly get it over to the body shop. Thanks for the help guys.
-Jim
