Tune up - TCCoA Forums
post #1 of 10 (permalink) Old 10-09-2006, 08:30 PM Thread Starter
RidinOnAir's Avatar
Tune up
Gas mileage has been going down hill. I'm going to put some seafoam in this weekend and oil change. I'm also replacing my spark plugs. I was wondering what spark plug wires to get. From what i've read, MSD and Ford racing seem to be the best bets. What year stang to get them from?
But should I replace the coils as well? Anything else I should replace while i'm at it (replaced the fuel filter a year ago)
RidinOnAir is offline
post #2 of 10 (permalink) Old 10-09-2006, 08:32 PM
MattsLE97's Avatar
Send a message via AIM to MattsLE97 Send a message via Yahoo to MattsLE97
Just get OEM ones motorcraft from jason and call it a day. Unless your having some ignitions problems you dont need to change the coil packs.
2000 dodge dakota 4.7L 4x4
Flowmaster 3" SI/DO 2.5
31" cooper stt tires (mud and off roading here I come)
MattsLE97 is offline
post #3 of 10 (permalink) Old 10-09-2006, 08:35 PM Thread Starter
RidinOnAir's Avatar
Some times it takes a lil while for the car to crank up. But now that I let the key sit in the one position for a second instead of going straight to starting it up (letting it prime up) it turns over a lil quicker. But nothing like a brand new car
as for the wires, I would like to have blue ones to match the loom under the hood, since they are around the same price. Is it part number FMS-M-12259-C462 (thats 96-04) But I think I need the ones from a 94-95 stang, is this correct. thanks
post #4 of 10 (permalink) Old 10-09-2006, 10:23 PM
Moderator & Teksid Whore
guitar maestro's Avatar
94/95 stangs came with the H.O 5.0, so those wires wont work...has to be 96-04
as far as the crank time is concerned, if it takes a while, thats usually a sign of aged parts showing their ugly faces...might be a combination of parts though, not necessarily just one
guitar maestro is offline
post #5 of 10 (permalink) Old 10-09-2006, 11:17 PM
Back in Black
ShadowDragon's Avatar
I have a set of stock motorcraft wires in blue from a 97, I'd think you could still get them. The FRPP don't seem to last as long unfortunately.
ShadowDragon is offline
post #6 of 10 (permalink) Old 10-09-2006, 11:52 PM
thunderbird96's Avatar
Send a message via AIM to thunderbird96 Send a message via MSN to thunderbird96 Send a message via Yahoo to thunderbird96
msd's last longer but the ford's are good.I would change all 4 o2' sensors.summit racing has nkg one's for 36 each wich is dirt cheap.I also will say you need to change fuel filter every 30,000 miles.I took my route 66 trip this past weekend and i used to get between 25 to 28mpg put my new sensors on last week and go 27mpg @ 80mph on cruise from arcadia oklahoma to wichita ,ks on I-35.I got 25mpg @70mph from harrisonville to joplin i had more in town city driving in kc before i left though. Before i changed i was getting low 20's high teen's with 80,000 on original sensors. i got better when i first bought the car at 40,000 miles. the numbers are all highway.It was even worse in city before i changed them
thunderbird96 is offline
post #7 of 10 (permalink) Old 10-10-2006, 11:21 AM
REPLACE YOUR FUEL PRESSURE REGULATOR,,,,
((located on the left side on top of manifold, next to egr valve...silver with a vacuum line on top))
tlpru is offline
post #8 of 10 (permalink) Old 10-10-2006, 08:13 PM
the regulator is on the drivers side not left.
post #9 of 10 (permalink) Old 10-10-2006, 10:37 PM
Thumbs up
I would at the minimum do a tune up with plugs and wires. For wires, I have found great performance and value with borg-warner selects, which are grey, and they have thick insulation--so they tend to have less issues with arching and work great. They are about 70-75 bucks at most autoparts stores-- which is in line with the motorcrafts from what I hear. Stay on top of the oil changes. Change your air filter and CLEAN THAT MAF SENSOR---this has added well over 30% more horse power for me, runs smoother, and gets me between 3-5mpg more. Plugs--copper cores are cheap and make your car run great, however they don't tend to last very long. I usually go with some type of platinum plug my self with all of my cars. But, ya know--no matter what brand of stuff you buy or how much you replace----every thing makes a difference, just keep the tires turning.
95Tbirder is offline
post #10 of 10 (permalink) Old 10-11-2006, 07:12 AM
wether's Avatar
The driver's side is left. When refering to left/right of a vehicle the frame of reference is from sitting in the driver's seat. Hence the driver's side is the left side of the car.
wether is offline
