Gas smell in Oil - TCCoA Forums
post #1 of 20 (permalink) Old 10-10-2006, 10:58 PM Thread Starter
WITootall's Avatar
Send a message via MSN to WITootall Send a message via Yahoo to WITootall
Gas smell in Oil
Ok so I have a 94 bird with the 4.6 in it. It starts up, runs rough, blow smoke like crazy, and if I try and rev it up it makes it to about 1700 then spits and spudders.
Pulled the dip stick out and the oil has a fuel smell to it.
I got the car like this, dont know how long the person tried to drive it like that, I havnt, just on the trailer and off.
Just wondering what I am lookin at possibly before I even tear the motor apart, just to get an Idea of what I am in for.
Any help/ideas appreciated.
WITootall is offline
post #2 of 20 (permalink) Old 10-10-2006, 11:09 PM
Post
You didnt state what color the smoke was,but based on your description,I would guess its black.
From your other descriptions,it sounds like youve got a fuel delivery problem,actually to much fuel,its flooding the eng.which accounts for gas smell in oil,its probably loaded your cats,and they are partially/or completely plugged,so no high revs
I would check the fuel delivery at the engine first,press.regulator,injectors etc.
If it just started,cats may be ok,but your going to have to change oil,quickly,or you will cause more damage then whats already there.
oldjd is offline
post #3 of 20 (permalink) Old 10-10-2006, 11:36 PM
Fry Rice Specialist
Casper's Avatar
most likely the pcm is faulty hanging 1 or 2 fuel injector open.
94-95 v8 mn12 notorious for the pcm to go out. either hang inctor open or no signal to fuel injector.
check into that one, and change the oil real quick.
CarDomain Page
Casper is offline
post #4 of 20 (permalink) Old 10-11-2006, 06:24 AM
Rolling-Thunder's Avatar
Cleaning the MAF sensor can't hurt, and might be the problem.
Also, bad plugs or plug wires could be possible.
Is the Check Engine Light on?
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #5 of 20 (permalink) Old 10-11-2006, 06:33 AM
Whining Intakes Rock
Al_Florida's Avatar
That would be my guess also. You can see if anyone on here is parting out a 94/95 and grab the EEC from them. Preferably an EEC from a 95.
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #6 of 20 (permalink) Old 10-11-2006, 11:55 AM Thread Starter
WITootall's Avatar
Ok so I am unsure how long this has been an issue with the car because I bought it like that. I had a 95 before that did something like this one is doing but that just ended up being plugs. Wasnt so lucky with this one.
The smoke is white, and has a strong fuel smell to it. After I got it home(trailered) I changed the plugs, wires, tried a different coil pack that I new was good, I had a K&N cone filter from my 95 that I put on it right away and checked the MAF sensor then. Other then these things I havnt done anything else to it yet.
This is why I was confused because I thought white smoke was antifreeze so I figued it was a blown head gasket.
I had thought about the cats being plugged and was always gonna disconnect the exhaust just to check but havnt done it.
The car runs with no check engine light coming on but the oil pressure gauge claims to have no oil and the check gauges light is on, but I think the gauge or sending unit is messed up on that because once it did flicker and was running with normal oil pressure then quit again.
How much would an EEC cost about?
This is why I come to you guys, get your thoughts before I start turning to many bolts.
post #7 of 20 (permalink) Old 10-11-2006, 12:10 PM
Al_Florida's Avatar
10 or 20 bucks give or take from someone on here. Shouldn't cost that much.
# 0 rows returned
post #8 of 20 (permalink) Old 10-11-2006, 12:33 PM
wether's Avatar
Definately sounds like the EEC. . . . .I had to replace the O2 sensors on mine when it did this. Come to think about it I had to replace 2 fuel injectors also because of the stupid computer. I thought since I was going to replace 2 fuel injectors, why not replace 8, and I did!
wether is offline
post #9 of 20 (permalink) Old 10-11-2006, 02:28 PM
The Great Obucina's Avatar
www.car-part.com
you can easily locate one
"Booyah". Stu Scott.
The Great Obucina is offline
post #10 of 20 (permalink) Old 10-11-2006, 02:53 PM
02 Explorer Pioneer
timb's Avatar
Or just go to the dealer and buy a new one which is updated and not prone to failure. 220,000 on my replacement EEC now
Birdless
timb is offline
post #11 of 20 (permalink) Old 10-11-2006, 08:51 PM
Fry Rice Specialist
Casper's Avatar
on my 94 before it also have the symptom of headgasket blow. you know, the steamy exhaust even on warm day. i suspect it might be bad intake gasket or something because the oil is clear as water but yet still losing coolant and the steamy exhaust. this is after the pcm change which fix the no signal to 2 of the injector. bought a headgasket replacement kit and tear down only until intake manifold. then decided too much of a job for me then installed everything back using the stock stuff and no more steamy exhaust. the oe intake manifold have a tell tell sign that it leak coolant into the intake manifold.carefully repositioned the gasket and torque it down and it's all fix.
CarDomain Page
Casper is offline
post #12 of 20 (permalink) Old 10-13-2006, 11:24 PM
BIG PETE's Avatar
PCV valve maybe? Also, it never hurts to do a compression test.
Pete
-97 XR-7
-5.0 Big Bore ...
Density Altitude = 4132'
1/8 mile: 8.75 @ 82
BIG PETE is offline
post #13 of 20 (permalink) Old 10-16-2006, 11:44 PM Thread Starter
WITootall's Avatar
Ok so just courious, I called up a dealer to get a price on a new one and they had no Idea what I ment. Is the EEC the entire computer for the car or what? Sorry I know probably a dumb question but appreciate the help.
post #14 of 20 (permalink) Old 10-17-2006, 12:11 AM
On pre-96 cars, the EEC is not the sole control unit of the car, however it controls like 90% of it. Pre-96 cars have an EDIS module (Electronic Distributorless Ignition System) that controls the spark timing for the car, but other than that everything is pretty much left up to the EEC (transmission, fuel delivery, emissions control, etc.)
post #15 of 20 (permalink) Old 10-17-2006, 08:30 AM
JustinH's Avatar
I'm pretty sure this is only a 3.8 thing. Anybody else?
JustinH is offline
post #16 of 20 (permalink) Old 10-17-2006, 08:35 AM
02 Explorer Pioneer
timb's Avatar
Nope the 94-95 4.6 uses an external EDIS as well. I just replaced mine a couple months ago
Birdless
timb is offline
post #17 of 20 (permalink) Old 10-17-2006, 09:03 AM Thread Starter
WITootall's Avatar
so if I refer to what I need to someone what do I tell them, the actual computer unit for the car or what?
post #18 of 20 (permalink) Old 10-17-2006, 09:11 AM
02 Explorer Pioneer
timb's Avatar
Yes they will probably know it by the name PCM (powertrain control module) computer, EEC. If they still don't understand tellthem it's the one in the passenger side kick panel
Birdless
timb is offline
post #19 of 20 (permalink) Old 10-17-2006, 11:26 AM
Umm, I thought the EEC hanging the injectors open was a 94 problem. Is it?
Bob
thunderferret is offline
post #20 of 20 (permalink) Old 10-17-2006, 11:33 AM
02 Explorer Pioneer
timb's Avatar
yes I definitely know 94 is aproblem year. I don't know about 95
Birdless
timb is offline
