pi swap - TCCoA Forums
post #1 of 5 (permalink) Old 10-11-2006, 03:40 PM Thread Starter
4.6Rebuild's Avatar
pi swap
here is the problem i did the pi swap on my 94 thunderbird and now i am looking to buy a 96-97 throttle cable and the ford dealer said he cant find any. is the 96-97 mustang throttle cable the same or is there one from a different car i can use any help would be appreciated.
Robert
OK, maybe not soon to be, but i will have it all sooner or later: PI heads, kooks headers, comp cams, 24# injectors, U/D pullies, J-mod, Aluminum driveshaft, and mustang convertor all into a 94 thunderbird.
4.6Rebuild is offline
post #2 of 5 (permalink) Old 10-11-2006, 03:41 PM
SR-71Blackbird's Avatar
should be able to find one no problem in a junk yard
1997 4.6L LX SPORT, rollin on 19's
http://www.cardomain.com/ride/856858
http://s12.photobucket.com/albums/a241/steviewonder13/
PI heads, PI intake, Comp 262's, Comp Valve Springs, Kooks headers, 3.73 TL, 180*T-stat, RSTB, lowered 1.5", A/C Delete Pulley, Custom exhaust. Block #2
-- SCT dyno tune 279RWHP & 310RWTQ - DD tune, SAE corrected
14.5 @ 97mph (need a higher stall, car bogged w/ stock converter + mickeys, lol)
SR-71Blackbird is offline
post #3 of 5 (permalink) Old 10-11-2006, 03:49 PM
95xbird's Avatar
96-97 Thunderbird/cougar throttle cables have been discontinued to my knowlage.I think there is 2 or 3 dealers left they may stock them.Ask your dealer to run a locator on it.Or if you can get the part number run it on www.partsvoice.com
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #4 of 5 (permalink) Old 10-11-2006, 09:12 PM
Resident drifter
slidebird91's Avatar
best bet would be a junkyard, I have found many t-birds and cougars at them. there are bound to be some 96/97s
slidebird91 is offline
post #5 of 5 (permalink) Old 10-11-2006, 10:27 PM
Baby Huey
warmaster259's Avatar
I fabbed up a little bracket for mine just to drive it, i bought a 96-97 to put on but my little bracket did the trick. (ill put the correct cable on when i get my motor back in the car.
Jim
warmaster259 is offline
