headers - TCCoA Forums
post #1 of 9 (permalink) Old 10-12-2006, 09:35 PM Thread Starter
94fastbird's Avatar
Send a message via MSN to 94fastbird
headers
hey guy's planning on putting headers on soon ? are they easy to install on these motors, with the motor in car?
94fastbird is offline
post #2 of 9 (permalink) Old 10-12-2006, 09:48 PM
Dont plan on making it a quick install. Had to jack up the engine a couple inches for some added clearance. Pull the valve covers too for additional room. Spent a few hours doing it, only to now have a ticking from the right header (suspesct a blown header gasket). Also do not use locking header bolts if you are installing JBA shorties, believe that is the reason for my gasket isse since the studs weren't long enough.
Just my 0.02
4.6 SOHC Auto,Zex 125 HP,BBK Fuel Pressure Regulator,90 mm Lightning MAF,Accel EDI Coil Packs,MSD 8.5mm Wires,Custom Cold Air Intake Box,"RichardM" Intake Tube,Inject Tech Chip 2 3/4 Exhaust from Headers Back,Magnaflow Mufflers,JBA Headers,180 T-Stat,Mark VIII Torque Converter,J-Mod,Kevlar Friction tes,Transmission Cooler,FRPP 3.73,Eibach 1.5" Lowering Springs,Tokiko Blue Shock/Struts MN12Performance Poly Front End Kit MN12Performance Poly IRS Kit, KVR Cross Drilled RotorsAluminum driveshaft,Bottle heater
Screw-Rice is offline
post #3 of 9 (permalink) Old 10-13-2006, 12:13 AM
The Great Obucina's Avatar
stay away from JBAs. They are crap made. The only real option is Kooks 3/4 length and they will be a ***** to do in the car.
Headers wont give you much power at all on the 94-95 wheez-o-matic motors.
"Booyah". Stu Scott.
The Great Obucina is offline
post #4 of 9 (permalink) Old 10-13-2006, 05:49 AM
It's either Kooks or stock manifolds.
I'm running the Stage 8 locking fasteners with my Kooks, and haven't had any leaks thus far.
-Rod
post #5 of 9 (permalink) Old 10-14-2006, 02:08 AM
twin turbo 281's Avatar
dont use paper gaskets supplied with most header kits. Use the stock multi-layer steel gaskets there reuseable! Yeah I would say kooks long tubes...I installed JBAs about 4 years ago when I first started moding my cat. There was little improvment
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #6 of 9 (permalink) Old 10-14-2006, 01:03 PM
Warlockguitarman's Avatar
Send a message via AIM to Warlockguitarman Send a message via Yahoo to Warlockguitarman
i have kooks and they sound awsome and help my motor make great power
96 pearl white 4.6 tbird: rebuilt npi block with pi heads, pi intake, crower stage 2 cams, shm high lift springs, L-MAF, 3.73's, marauder converter, jmod, kooks headers, xpipe, no cats, 2.5 in exhaust, no mufflers, a dyno tune, lots of interior work, 1 in drop with lots of new bushings, 18 in rims. 279 hp 319 tq. curently running 13.9 at 101 mph with a 2.1 60 time in 100 degree weather while having some nasty spark knock. Soon to have higher stall, aftermarket intake manifold, weight reduction, and hopefully a nice shot of the giggle gas.
Warlockguitarman is offline
post #7 of 9 (permalink) Old 10-14-2006, 06:01 PM
Send a message via AIM to Trick Bird
I have the ss auto chrome had no problems an i like them.
95' lx 4.6
true dual exhaust, mass air, 9 in k&n, 3:73 posi, 9mm ford racing wires, screamin demon coils, solid rubber trans mount, cobra r hood, clear corners, chrome bullit replicas.
Trick Bird is offline
post #8 of 9 (permalink) Old 10-15-2006, 12:15 AM
Baby Huey
warmaster259's Avatar
me too
Jim
warmaster259 is offline
post #9 of 9 (permalink) Old 10-15-2006, 12:22 AM
VicRattlehead's Avatar
ssauto = jba same junk
CMP Drag Racing
VicRattlehead is offline
