Which year 4.6 block should i use?? - TCCoA Forums
post #1 of 10 (permalink) Old 10-14-2006, 12:25 AM Thread Starter
Gator1980's Avatar
Send a message via Yahoo to Gator1980
i going 2 build a 4.6 engine for my 95 bird that is bored and stroked to 301 cubic inches and will produce around 600hp with nitrous. im using a forged rotating assembly and i just want 2 know what year of the 4.6 engine block is the best?? thanx 4 all ur info!!
Owning a 9 second ricer is like coming out of the closet. At 1st everybody is suprised, but in the end you're still gay.
Gator1980 is offline
post #2 of 10 (permalink) Old 10-14-2006, 12:32 AM
The Great Obucina's Avatar
dont stroke it, go Big Bore. You will need an aluminum block for it. Either a 96-98 Cobra block, 93-98 Mk8, or explorer/mach1/marauder.
explorer(2002-2004)
Mach1(2003-2004)
Maruader(2003-2004)
some 99/01 Cobra blocks were *reportedly teksids* but all were aluminum.
"Booyah". Stu Scott.
The Great Obucina is offline
post #3 of 10 (permalink) Old 10-14-2006, 02:22 AM
Refrigerator Raider Hater
GreenBird's Avatar
Well it is possible to big bore an iron block, but it requires wet sleeves, which cost so much more than dry sleeves, your better off buying an aluminum block and dry sleeving it.
The cost of a big bore shortblock over a stroker is often the cost of an aluminum block, or less.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #4 of 10 (permalink) Old 10-14-2006, 01:05 PM
Warlockguitarman's Avatar
Send a message via AIM to Warlockguitarman Send a message via Yahoo to Warlockguitarman
or make a big bore stroker which will be about a 324 i believe, which is my plans for my next motor. m but yes alluminum block like they said
96 pearl white 4.6 tbird: rebuilt npi block with pi heads, pi intake, crower stage 2 cams, shm high lift springs, L-MAF, 3.73's, marauder converter, jmod, kooks headers, xpipe, no cats, 2.5 in exhaust, no mufflers, a dyno tune, lots of interior work, 1 in drop with lots of new bushings, 18 in rims. 279 hp 319 tq. curently running 13.9 at 101 mph with a 2.1 60 time in 100 degree weather while having some nasty spark knock. Soon to have higher stall, aftermarket intake manifold, weight reduction, and hopefully a nice shot of the giggle gas.
Warlockguitarman is offline
post #5 of 10 (permalink) Old 10-15-2006, 12:20 AM
Baby Huey
warmaster259's Avatar
I dont think you can go that big, i think they take them out to like 301.
Mines a 284 with it being .20 over
Jim
warmaster259 is offline
post #6 of 10 (permalink) Old 10-15-2006, 12:32 AM
The best block I was told to get was a 99gt it had extra webbing and other stuff that ford took out the next year run. to save money Thats what Jerry told me. I had it bored .20 over. From what I have heard its still running strong after 5 years of some serious use.
mazda6 Sport- 06
100hp worth of Stickers coming soon
Blake-vortech is offline
post #7 of 10 (permalink) Old 10-15-2006, 01:46 AM
Thunder Canary's Avatar
Send a message via AIM to Thunder Canary
its got a nice kick to it
A nut is a nut and a bolt is a bolt. Wrench 'em off!
I used to dream about this car now I drive it- ditto
SVO Heads
SVO Intake
SHM cams
JE pistons
Eagle rods
Cobra crank
Thunder Canary is offline
post #8 of 10 (permalink) Old 10-15-2006, 02:53 AM
GreenBird's Avatar
big bore means a 3.7" bore, combined with a 3.75" stroker crank, does net 324cid.
96 Alpine Green V8
post #9 of 10 (permalink) Old 10-15-2006, 03:00 PM
BIG PETE's Avatar
If you big bore or not, I really like the aluminum blocks. I made my big bore from an 03 Aviator block, but it's generally regarded that if you go aluminum, the Teksid blocks are the best. They came in the Marks and older, NA Cobras. Nocking almost 100 lbs off the nose really made the steering wheel feel better. The car doesn't feel as nose heavy in turns and is in general a lot more fun to drive. Anything to knock weight off these cars is a good thing in my book. Loosing the 80 lbs of weight difference is like getting another 8 hp for free from an identical iron block.
Pete
-97 XR-7
-5.0 Big Bore ...
Density Altitude = 4132'
1/8 mile: 8.75 @ 82
BIG PETE is offline
post #10 of 10 (permalink) Old 10-18-2006, 11:36 PM Thread Starter
Gator1980's Avatar
you guys are awesome! thanx for all your help!!
