DPFE Sensor Swap - TCCoA Forums
post #1 of 6 (permalink) Old 10-14-2006, 09:00 PM Thread Starter
DPFE Sensor Swap
I am going to replace my DPFE sensor on my 94 t-bird 4.6L to fix a check engine light issue. I located it this morning on the back side of the throttle body by the firewall and it looks like a real pain to do anyone have any tricks on this one to make it easier???? thanks
jmsprang is offline
post #2 of 6 (permalink) Old 10-15-2006, 12:29 AM
removing the cowl will free up a ton of room for this(its still doable without, but its a pain), after that its cake, just unplug the connector on the back, take off the 2 bolts holding it to the bracket, and remove the 2 hoses that go to the egr tube
post #3 of 6 (permalink) Old 10-15-2006, 02:23 AM
use a ratcheting wrench to remove it and when u go to put it back on place a little soapy water on the vacuume line to get it to slip in easier
promanron is offline
post #4 of 6 (permalink) Old 10-19-2006, 10:51 PM
2x on the above posts, removing the plastic cowl will make seeing and feeling for things WAY beter
delash_81 is offline
post #5 of 6 (permalink) Old 10-19-2006, 11:06 PM
jk69cat's Avatar
its no easy task on crown either
mn12 less!
jk69cat is offline
post #6 of 6 (permalink) Old 10-20-2006, 08:30 AM
nickmckinney's Avatar
Another option - buy a performance tune. The tune I have assumes the DPFE is fine and ignores its output while still running the EGR system correctly. My car "was" on its third DPFE, now the defective DPFE takes up space while the PCM runs the EGR system just fine.
nickmckinney is offline
