would bad gas foul a plug? - TCCoA Forums
post #1 of 8 (permalink) Old 10-16-2006, 09:12 AM Thread Starter
JustinH's Avatar
Hey Guys,
Trying to recover from the weather disaster here, i've been staying at my girlfriends moms house about 40 minutes from my apt, power has been out since thursday but we are all ok.
I did something stupid, I bought gas at the indian reservation, and I think I got some bad gas in the 98 4.6 f150.
It was sputtering really bad, then started throwing a blinking check engine light (misfire).
Would bad gas foul a plug? I put alot of drygas in the tank, and filled about 1/4 of the tank up with good 93 octane gas.
When you first start the truck up it runs really bad and shakes, but when it warms up it runs a little better but still not right.
The plugs are 12c motorcraft coppers about a year old, and 20k miles on them.
I'm going to put a set of autolite platnium plugs in the truck, and see if that helps it out. This thing is a bit of a bear to put plugs in, so i'm not looking forward to it.
Thanks.
JH
JustinH is offline
post #2 of 8 (permalink) Old 10-16-2006, 09:19 AM
Rolling-Thunder's Avatar
Any chance the MAF sensor is going bad?
Just unplug it and give her a test drive.
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #3 of 8 (permalink) Old 10-16-2006, 09:26 AM Thread Starter
JustinH's Avatar
Thanks steve, i'll check that out.
I had to drive the thing into the office today, but when i get it home i'll check that out.
Good thing I took half a day off so i'll have daylight to figure this one out.
JustinH is offline
post #4 of 8 (permalink) Old 10-16-2006, 09:30 AM
FordFanatic's Avatar
if you think you got some bad gas i would change the fuel filter asap. i can remeber my dad getting a bad tank of gas and he had to change the filter 3-4 times (had a clear case so you could see the crap in the filter).
FordFanatic is offline
post #5 of 8 (permalink) Old 10-16-2006, 11:05 AM
Marl's Avatar
Send a message via AIM to Marl Send a message via Yahoo to Marl
You bet bad gas will foul a plug in an instant. If you are suspecting bad gas run the car as low as you dare then fill it up with as much as it can hold of some good gas. Then change the fuel filter. It may take a tank or so but it will come out.
Marl
1995 4.6L XR7 Dual Guage Pod with Oil and Temp., 255/60R15 Yokohama Avid S/T's, Screamin' Demon Coil's with Live Wires, K & N, modified stock oil pressure gauge, air silencer removed, stock air box, trans and tune by Darrin, TC by Dirtydog
Sometimes when I reflect back on all the beer I drink I feel ashamed. Then I look into the glass and think about the workers in the brewery and all of their hopes and dreams. If I didn't drink this beer, they might be out of work and their dreams would be shattered. Then I say to myself, 'It is better that I drink this beer and let their dreams come true than to be selfish and worry about my liver.'
Spend your money on your ride and not your girl. It'll last longer and fewer people have been in it!
Marl is offline
post #6 of 8 (permalink) Old 10-16-2006, 12:11 PM
MR95XR7's Avatar
Send a message via AIM to MR95XR7
There could of been some sort of a leak at the place where you got the gas from and some water got in to there tank , hence you got some water in your tank!Also could have been low octane to begin with. With new plugs clean m.a.f a new fuel filter, and some STP fuel boost. All should be ok then.
"Alive man is pliable and weak
Dead he is firm and strong"
- sun pin.
"There is no better weapon than a marine and his rifle"
http://www.cardomain.com/ride/761335/1
MR95XR7 is offline
post #7 of 8 (permalink) Old 10-16-2006, 04:13 PM Thread Starter
JustinH's Avatar
Thanks guys, i got it fixed.
Turned out to be a wet plug in the rear of the passenger side bank.
Put 8 autolite platniums in it, and a couple cans of drygas, seems to be fine for now.
Doing plugs on those f series trucks is a bit of a pain, but after doing it a few times you kinda know what to expect.
JustinH is offline
post #8 of 8 (permalink) Old 10-17-2006, 12:01 AM
Refrigerator Raider Hater
GreenBird's Avatar
dry gas works well for bad gas as it is anhydrous, and will "soak up" any water.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
