Weird problem... - TCCoA Forums
post #1 of 7 (permalink) Old 10-16-2006, 03:29 PM Thread Starter
Weird problem...
When I roll the power windows down OR turn the wheel at idle (parked) the rpm's drop 300 or when I go from park to drive is will drop in rpm's too. What’s the deal with this? Is this a power issue?
post #2 of 7 (permalink) Old 10-16-2006, 03:53 PM
MattsLE97's Avatar
Send a message via AIM to MattsLE97 Send a message via Yahoo to MattsLE97
when you roll down your windows your using electricity which makes the alternator work harder to keep your battery charged thus making the engine go down in rpms because your not hitting the gas to compensate same with turning the wheel the ps pump is run the same way your putting strain on the pump when u turn making the rpms go slightly down. As for the park to drive rpm drop im guessing once the tranny is engaged the tc and trannys parts will lower the rpm just from being engaged
-Matt-
2000 dodge dakota 4.7L 4x4
Flowmaster 3" SI/DO 2.5
31" cooper stt tires (mud and off roading here I come)
MattsLE97 is offline
post #3 of 7 (permalink) Old 10-16-2006, 04:21 PM Thread Starter
Well I stalled a couple times, I'm thinking a power steering flush to help free up friction. And the alternator is 10 years old, how long do they normally last for?
post #4 of 7 (permalink) Old 10-16-2006, 04:28 PM
wether's Avatar
I would have the alternator checked out. . . .it sounds like maybe the alternator and/or battery may be going.
wether is offline
post #5 of 7 (permalink) Old 10-16-2006, 04:45 PM
MattsLE97's Avatar
ya take it to autozone and have the alternator checked and battery checked and go from there. I PS fluid change would be a good idea too if its the original fluid
-Matt-
post #6 of 7 (permalink) Old 10-16-2006, 04:48 PM
Birdless
Grasshopper's Avatar
Send a message via AIM to Grasshopper Send a message via Yahoo to Grasshopper
And if you need to get a new alternator, I'd pony up for OEM...my opinion.
Do you get flickering? If so, check the spliced small wires that go to the alternator from the harness.
A man may smile and bid you hail
Yet wish you to the devil;
But when a good dog wags his tail,
You know he's on the level.
--author unknown
Grasshopper is offline
post #7 of 7 (permalink) Old 10-16-2006, 04:50 PM Thread Starter
Yes, yes i do, i well look first thing after work
-Matt-
The last time it was changed was 15k miles ago
