pi motor and motor mounts please help!! - TCCoA Forums
post #1 of 10 (permalink) Old 10-17-2006, 03:43 PM Thread Starter
Mn12KnightRyder's Avatar
Exclamation pi motor and motor mounts please help!!
Hello to all no time no talk to a few .
Im doing the pi motor swap, THe motor i have is a 99 mustang . Everything is going well,untill i ran into the motor mounts the motor mounts out of the tbird are the solid motor mounts i bought from mn12 performance. The mounts are not mounting on the block. Is there somthing special i'll have to do ?? anyone thats done the mustang pi motor swap can you please help me . Do i need to purchase regular mounts and brackets ??? any info can help because its not bolting in. thanks
Rigel
94 tbird- 00 pi stang motor, Steeda intake system, Accufab 70mm throttle body,upper plenum, dual flows from flowmaster, transgo shift kit, B&M tranny cooler, aluminum driveshaft, 4.10 frpp, Mark8 TC, ScT chip,18x9 Rims.
04 cadillac ctsV--my monster, that takes the wife n kids out,and gets the groceries.
Mn12KnightRyder is offline
post #2 of 10 (permalink) Old 10-17-2006, 03:45 PM
Like Titles Matter
kdanner's Avatar
Use a grinder.
1998 GT - [email protected]
generated by sloganizer.net
kdanner is offline
post #3 of 10 (permalink) Old 10-17-2006, 04:38 PM
Tx_Cat's Avatar
I used my old motor mounts without any problems at all.
Tx_Cat is offline
post #4 of 10 (permalink) Old 10-17-2006, 04:49 PM Thread Starter
i have a 99 though the brackets are inverted TX cat plus my old brackets are hitting the block and has about n 1" between them . Kdanner grind what ?? the brackets ??
post #5 of 10 (permalink) Old 10-17-2006, 05:38 PM
girdnerg's Avatar
I had to do some grinding also. Just figure out which holes you need on the block and grind the others off the block until the mounts fits correctly...no mount modifications needed.
Rob
girdnerg is offline
post #6 of 10 (permalink) Old 10-17-2006, 09:33 PM
Chapter Director Coordinator
jamesD's Avatar
NO NO NO NO NO
the mounts themselves need to be ground first.. Big Scott posted a pic on here a while back showing where.. if you line it up you will see where
AFTER that is done, you may need to trim a tad off the block itself because the solid mount may rub
and don't tell me i'm wrong.. i have a windsor block IN the car NOW.. and i know at least 3 guys that were there during the install to back me up
you need help with anything else bro.. drop me a line
I bust ARP bolts by hand...
If Guns kill people, then...
...pencils miss spel werds
~Gun Owners of America
jamesD is offline
post #7 of 10 (permalink) Old 10-17-2006, 10:01 PM
VicRattlehead's Avatar
james is right. i have had my 99 engine in my car for 5 years.
here is the pics.
original in back, modified in front
you want to remove the part highlited in red.
and here it is in the car.
http://members.tccoa.com/lxbird96/tb...bird1533sm.jpg
CMP Drag Racing
VicRattlehead is offline
post #8 of 10 (permalink) Old 10-17-2006, 10:27 PM Thread Starter
Thanks alot james and Vic. The pictures is a great help , ill try tomorow and let you know how it went. So do i cut the red off and grind the mount ,and how much d o i grind off?? Thanks James i lost your # if you can pm me it that'll help out .. Thanks
Rigel
post #9 of 10 (permalink) Old 10-18-2006, 09:34 AM
jamesD's Avatar
what you see if red needs to be ground off the tbird mounts.. mock fit the solid mounts to the brackets and fit them to the block.. if she still don't fit (ie: solid mount hits the block) carefully grind the block down in that spot
don't forget to hi-temp paint the spot you ground.. cuz it'll rust
4O7*46O*8756
jamesD is offline
post #10 of 10 (permalink) Old 10-18-2006, 05:30 PM
SOB I didnt even think about rust, is it just eyesore if I ever have the engine out again or will it eventually cause the rust to spread?! When I swapped in my PI block I just ground the block, it was only like 1/2" IIRC.
All Glory to God!
RIP JOHNNY LANGTON
96 LX PI/Jspec Pearl White. She enjoys eating ricers for breakfast
-MODS-
2002 PI 4.6L - Jspec Trans built by Darrin - 04 Marauder converter - Hayden 679 Trans cooler - Engine cooling modification - SCT Xcal2, tuned by Lonnie - 02 GT MAF and 99 GT Intake tube - removed silencer - 255 lph HP fuel pump - Aluminum Driveshaft - 3.73 TL - 245/60/15 BFGoodrich Radial T/A's - PBR front brakes - SCP Rear torsional load brace - SCP Solid rubber motor, transmission mounts - Rear Strut Tower brace and Diff cover brace by Rod
96_LX is offline
