Gratification of an oil change - TCCoA Forums
post #1 of 11 (permalink) Old 10-17-2006, 10:54 PM Thread Starter
Bigiron383's Avatar
Talking Gratification of an oil change
As crappy as thet stock oil filter location is, it's really gratifing to complete an oil change. Now, is there a larger oil filter that will work on a stock engine?
Bigiron383 is offline
post #2 of 11 (permalink) Old 10-17-2006, 10:58 PM
Who is John Galt?
Sure there is . . . get an oil filter relocation kit and you can use a motorcraft FL1A. I think that you'll be able to hold an extra quart of oil.
Fringe benefit: you can put that filter in a much nicer position.
"Won't work, can't be done"
cougar_guy04 is offline
post #3 of 11 (permalink) Old 10-18-2006, 12:15 AM Thread Starter
Bigiron383's Avatar
Red face Got one from Northern
just too lazy to install it.
post #4 of 11 (permalink) Old 10-26-2006, 11:30 AM
Traveler's Avatar
And extra quart? I don't think so. I've used an FL1A for a while now, and with the extra hose, and the larger filter I can get maybe 5.5 quarts in. I still put 5 quarts in at oil changes then check to see how full it is. Its usually in the "enough" range on the dip stick. (P.S. Is it still a dipstick when its actually a flexible steel cable?)
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #5 of 11 (permalink) Old 10-26-2006, 11:46 AM
Who is John Galt?
That's just what I'd been told in the past by some people . . . guess I was told wrong. I haven't been able to verify that for myself since I really don't want to sink anymore mod money into the Cougar for now.
post #6 of 11 (permalink) Old 10-26-2006, 05:32 PM
IIRC, my DOHC XR7 takes right around 7 quarts with the FL1A filter and 8-AN lines. After this winter, it should take about 8 1/2 quarts per oil change.
-Rod
post #7 of 11 (permalink) Old 10-26-2006, 07:22 PM
Traveler's Avatar
The only changes you've made are the filter and the lines to and from it?
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #8 of 11 (permalink) Old 10-26-2006, 07:40 PM
Yep. Remember though, it's a DOHC with a 6 quart pan, and I'm currently using 8-AN (1/2") lines for the oil filter relocation.
-Rod
post #9 of 11 (permalink) Old 10-26-2006, 07:56 PM
Traveler's Avatar
Ahhh yea, forgot about the ol' DOHC.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #10 of 11 (permalink) Old 10-26-2006, 08:42 PM
Carlover007's Avatar
It depends on how much hose you run and where you put it.
Carlover007 is offline
post #11 of 11 (permalink) Old 10-26-2006, 10:22 PM
Traveler's Avatar
LOL Thats true, just think of how much oil you could get if you mounted the remote oil filter in the trunk!
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
