tranmission ? - TCCoA Forums
post #1 of 9 (permalink) Old 10-19-2006, 10:54 PM Thread Starter
tranmission ?
about to swap a97 CV motor into my 96 bird.i was going to swap engine and transmission till i visited this site and learned that the tran. for the CV had alonger tailshaft.
been reading alot of threads and a tranny cooler seems to be a high priority.are these trannys really heat sensitive?the motor in the bird had heat related failure.just wondering if the transmission is fried too.
also would the CV torque converter help as the MVIII's and marauder converters do?
shelbyseven is offline
post #2 of 9 (permalink) Old 10-20-2006, 12:14 AM
Darrin's Avatar
Yes to the cooler and no to the torque converter.
Darrin
Darrin is offline
post #3 of 9 (permalink) Old 10-20-2006, 06:06 PM Thread Starter
darrin,if the torque converter want "help" will it at least work,properly?haven't been able to get the bird torque converter off.one piston is rusted to the cylinder,it;'s soaking in marvel mystery oil now...
post #4 of 9 (permalink) Old 10-20-2006, 07:27 PM
The Great Obucina's Avatar
why not pick up a mk8/mustanggt/mach convertor?
"Booyah". Stu Scott.
The Great Obucina is offline
post #5 of 9 (permalink) Old 10-20-2006, 09:47 PM Thread Starter
$'s at the moment....what does a marauder,gt,mach torque converter run?
post #6 of 9 (permalink) Old 10-20-2006, 10:21 PM
you can find a used one on modulardepot for kinda cheap
new ones should be around or under 200$.
post #7 of 9 (permalink) Old 10-21-2006, 03:08 AM
girdnerg's Avatar
Originally Posted by FordPartsCounter
Oh yeah..I sell the 03 Marauder T/C's for $159.95...Just for the info
Jason
I believe there's a $50 core charge, but ford will take the CV back as a core. At least they did on my mark unit.
Rob
girdnerg is offline
post #8 of 9 (permalink) Old 10-21-2006, 07:35 AM Thread Starter
thanks for the info...wondering if i can use the CV torque converter. bought the t-bird with a bad engine,it was run hot.so i don't know if the tranny is good.would hate to put a "good" torque converter on a bad transmission and screw the TC up...
post #9 of 9 (permalink) Old 10-21-2006, 08:47 AM
Darrin's Avatar
The vic converter will work. The stall speed won't be improved, but it will work.
Darrin
Darrin is offline
