3V into a MN12 does fit - TCCoA Forums
post #1 of 57 (permalink) Old 10-20-2006, 03:09 PM Thread Starter
nickmckinney's Avatar
http://forums.modulardepot.com/showthread.php?t=92361
nickmckinney is offline
post #2 of 57 (permalink) Old 10-20-2006, 05:07 PM
infamous's Avatar
That's great, I've been wanting to see one in there since I have most of the top end laying around.
-"Love me or hate me, you'll never forget me."
-2004 Lincoln Aviator, 1999 Saturn SL1, 1979 Bronco (460cid), 2011 SHO (402a, massaging seats, performance pack)
-no more: 1994 Corvette, 1995 Thunderbird LX 4.6
-MBA in progress, MS Automotive Engineering, BS Mechanical Engineering
infamous is offline
post #3 of 57 (permalink) Old 10-20-2006, 05:53 PM
95xbird's Avatar
Thats awesome.I think that is gonna be the new swap of the future.
Infamous get yours started and write an article on it already!
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #4 of 57 (permalink) Old 10-20-2006, 06:36 PM
Baby Huey
warmaster259's Avatar
Jim
warmaster259 is offline
post #5 of 57 (permalink) Old 10-20-2006, 07:09 PM
Moderator & Teksid Whore
guitar maestro's Avatar
interesting.....they even swapped the cluster from the GT into it......i wonder if they are using the GT's EEC to run the whole show
guitar maestro is offline
post #6 of 57 (permalink) Old 10-20-2006, 08:13 PM
Chapter Director Coordinator
jamesD's Avatar
is that the gt cluster? or is it scott's magic?
I bust ARP bolts by hand...
If Guns kill people, then...
...pencils miss spel werds
~Gun Owners of America
jamesD is offline
post #7 of 57 (permalink) Old 10-20-2006, 09:37 PM Thread Starter
With the drive by wire issues I would imagine the GT EEC was installed also. I wonder if someone in the future will make a standard cable throttle body for that intake for swappers.
post #8 of 57 (permalink) Old 10-20-2006, 10:31 PM
tomaso12's Avatar
i was wondering the same thing myself, but look at the 4 guages between the speedo & tach...deffiantly from a s197
All MN12/FN10 PA/NJ/MD/DE/NY people please check out: TSTaCC, feel free to register & say hi
'Krissy' 1997 Thunderbird LX Sport 281ci
Custom doesn't come in a Box
Slide or Die
tomaso12 is offline
post #9 of 57 (permalink) Old 10-22-2006, 12:30 AM
assasinator's Avatar
add a cobra throttle body and there are no drive by wire issues. it isn't a simple matter to use the factory piece. it is doable. 'm sure one day one of you will put a 5.4 3v as it is lower than 4.6 3v by a bunch.
edit: i noticed thew harness is connected to the TB, so it looks like the 06 pcm harness is in place.
96 gt. .93 teksid ported 4V, forged, 64mm turbo,sniper tune, BA2600maf, 90/10's, granitelli rear LCA's, 3.90's, QA-1 200in/lb fronts, tubular everything, coil overs.
2011GT, 300A, base model, 3.73, brembos, spoiler delete, candy red. current mods: lethal off road x-pipe, airraid cai, lethal 93 tune, roush axle back mufflers
assasinator is offline
post #10 of 57 (permalink) Old 10-22-2006, 12:59 AM
Refrigerator Raider Hater
GreenBird's Avatar
how is a 5.4L going to be lower than a 4.6L? or are you talking about powerband?
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #11 of 57 (permalink) Old 10-23-2006, 10:07 PM
it is lower than a 4.6 3v. look at the intake runner where they peak, and also the intake exits at the front over the alternator. mine fits under the stock hood without hitting it when a stock 4.6 2v elbow is used. i don't have a number to satisfy you, but i own one and i have compared them side by side, and my intake elbow sits level with the runners. the point where the 4.6 3v is tall enough to matter is the front at the inlet. this intake is similar to the BA falcon unit with a small difference being location of the inlet and the height of the inlets. this motor is designed to fit into the BA falcon. with the inlet on mine being in the middle there is added hood clearance over the front entrance 4.6 3v. that's just how it is.
my powerband with lightly modded settings is idle to 6000. when i changed the rev limiter out of fear of blowing it up i lost 4 mph. i have yet to run 82mph since i changed it. but i can't afford to blow it up until forgings go in. i just have too many projects whether it be intake fabrication or headers or any other miriad of ideas i try. i have managed to slow down when changing from the original setup. i read an article from australia where they found 325rwhp from a 5.4 3v using the stock long runner intake with non-cam bolt-ons. they noted the long runner ran better than expected considering it's 14" runner length. i am finding the same thing. the last attempt i will make with mine is to taper the runner to 9" mark and see if it picks up MPH. i still haven't retarded the cams. so there is plenty still in it from that.
post #12 of 57 (permalink) Old 10-24-2006, 07:06 AM
Toombs's Avatar
From the builder...
In this car, the engine, 5sp auto trans, eecV pcm, instrument cluster, smart junction box, fpdm, are all from 2005 Mustang GT. Clearance for belt driven accessories is about the only thing that didn't really pose a problem for this swap.
Mike
- DOHC 4.6
- 4.56 Trac-Loc
- DirtyDog Converter (3,800)
- SCT Micro Tuner from Blue Oval Chips
- 13.24 @ 103mph
ToombsRacing.com
Toombs is offline
post #13 of 57 (permalink) Old 10-24-2006, 11:46 AM
BIG PETE's Avatar
Hmm...if the belts fit fine, maybe converting an 03 Cobra motor to the 3V GT belt layout could be a possibility?
Pete
-97 XR-7
-5.0 Big Bore ...
Density Altitude = 4132'
1/8 mile: 8.75 @ 82
BIG PETE is offline
post #14 of 57 (permalink) Old 10-24-2006, 09:15 PM
he will enjoy the broad torque band from VCT. the drive by wire throttle control and torque sensing limitations have long been overcome by tuning. most bolt on 4.6 3v's are in the 290-300 rwhp range.
post #15 of 57 (permalink) Old 10-24-2006, 09:22 PM
BIG PETE's Avatar
He won't be seeing those kind of numbers in a MN-12. Our drive trains have more losses than a Mustang's. We have more rotating mass with the longer driveshaft, automatic trans, and IRS...it sucks, but there's nothing you can do to really get around it. 290-300 is really optomistic for our layout, I'd definately expect less.
Pete
-97 XR-7
-5.0 Big Bore ...
1/8 mile: 8.75 @ 82
BIG PETE is offline
post #16 of 57 (permalink) Old 10-24-2006, 09:50 PM
that's no good.
post #17 of 57 (permalink) Old 10-25-2006, 12:04 AM
GreenBird's Avatar
don't forget the only real headers are only 3/4 length, and expensive.
96 Alpine Green V8
post #18 of 57 (permalink) Old 10-25-2006, 03:22 PM
Gauge master
scotthrbacek's Avatar
Send a message via Yahoo to scotthrbacek
I wish I could take credit for that cluster, but that definately looks like the Mustang cluster.
Scott
A book sale at the library? Why even bother? Why would I want to buy a book, when I didn't want it for free?
-Homer Simpson
scotthrbacek is offline
post #19 of 57 (permalink) Old 11-08-2006, 12:26 AM
TGJ
Baddest N/A NPI in Canada
TGJ's Avatar
I will be damned. Curious to know what that car makes. Definitely a Mustang Cluster though and I would be even more impressed if it has the "MyColor" feature as well.
TGJ is offline
post #20 of 57 (permalink) Old 02-01-2013, 03:04 PM
Tbird1997's Avatar
3v swap
Link failed at the top. Wondering if anyone has an updated link to it.
Been reading more about the 3v swap. Looks like a lot of work but even worse looks like its costing most Mustang guys $1500-2000 just to do the swap, not including the motor.
From what I've read big problem areas are:
Exhaust manifolds need adapters for 3v heads
Cobra throttle body so you can run the throttle cable (mustang is electronic)
Different intake tube and filter (must use your own MAF or lightning MAF with updated tune)
Cam locks for VCT
Something about the spark plug boots (I think on the 3v it is a longer reach)
return style fuel system
couple of custom brackets (power steering pump, throttle body)
tune of course
-I believe that was everything? I've read like 100 threads on it in the last week
-Patrick
Tbird1997 is offline
post #21 of 57 (permalink) Old 02-01-2013, 03:20 PM
Why does PS need a custom bracket? There's plenty of clearance in the engine bay for the pump to fit at the "head mount". The FN10 I got my Machviator motor out of had the pump mounted in the 3V location, so it definitely fits these cars.
post #22 of 57 (permalink) Old 02-01-2013, 06:36 PM
Cam locks for VCT
tune of course
You would actually run mn12 exhaust manifolds if you did a 3V swap?
Thou shall be arrested and charged with blasphemy against all that stands for horsepower!
post #23 of 57 (permalink) Old 02-01-2013, 07:22 PM
Tbird1997's Avatar
I will have to look at it. I didn't even think about it I just read that the mustang guys had trouble with it. I guess they do have less room than we do tho.
Lol I would at least get them ported! Give me yours Ill give you $50 bucks
-Patrick
post #24 of 57 (permalink) Old 02-01-2013, 07:55 PM
my stock exhaust manifolds for $50?: deal. I am able to receive paypal payments 24/7, 365/yr
post #25 of 57 (permalink) Old 02-01-2013, 08:36 PM
aw, thought it was a new thread.
son of mad dog is offline
post #26 of 57 (permalink) Old 02-01-2013, 09:28 PM
you gave me an idea. Gonna bump up this thread every 6mo for the news to click it thinking the same thing lol
post #27 of 57 (permalink) Old 02-01-2013, 10:27 PM
Tbird1997's Avatar
Ha guess I should have specified long tubes before I opened my mouth
-Patrick
post #28 of 57 (permalink) Old 02-01-2013, 11:00 PM
yup too late...awaiting paypal payment now
or just save your $50 for when the other set gets done...might need it to bid for them
post #29 of 57 (permalink) Old 02-01-2013, 11:57 PM
Pfft, not in that area. It's more cramped on these. The mustang guys either are going out of their way for the factory type fitment or their hydroboost lines end up too long. Not really an issue with these cars.
Plus, there's a HUGE benefit to using that pump arrangement, in particular on this chassis. Ever look at the oil filter arrangement?
post #30 of 57 (permalink) Old 02-04-2013, 02:21 PM
Tbird1997's Avatar
Wow didn't even notice that the oil filter was that far forward.I wish there was someone on here that has completed this swap that would have some insight on these little things. Glad you pointed that out tho Matt.
I think sometime later today or tomorrow I will start pricing the extra parts together and see if its really going to cost $1500 just for the swap. (Dont get your panties in a bunch just because I'm doing a little reading doesn't mean I'm swaping this motor anytime soon)
Wish these 3v's were plug and play like the PI motors are!!
-Patrick
