my car wont crank - TCCoA Forums
post #1 of 25 (permalink) Old 10-21-2006, 06:01 PM Thread Starter
Send a message via AIM to Stevie G
my car wont crank
as the title says. my car is having a problem when i go to start it, everything works the fuel pump goes but just nothng happens when i turn the key all the way. i dont have a multimeter so i can't see if its the battery, but i dont thnk it can be that because everything in my car can work, even my stereo system. im just lost and fed up with my car
Stevie G is offline
post #2 of 25 (permalink) Old 10-21-2006, 06:24 PM
BIG PETE's Avatar
Do you hear any clicks or anything? If the battery is good, it's probably the starter / solenoid combo that's gone bad. Also, check your fuses and everything pertaining to the starter.
Pete
-97 XR-7
-5.0 Big Bore ...
Density Altitude = 4132'
1/8 mile: 8.75 @ 82
BIG PETE is offline
post #3 of 25 (permalink) Old 10-21-2006, 06:47 PM Thread Starter
fuses are all good. and i hope it has nothing to do with my actuall starter. could any grounds have anyting to do with this?
Stevie G is offline
post #4 of 25 (permalink) Old 10-21-2006, 06:51 PM
David_viny's Avatar
I second that it may be the solenoid. U can hit it and it might help for a short time and if u really need to get somewhere u can jump it with a screwdriver.
1995 T-bird 4.6l - Eibach lowering springs, Cobra R hood, One 12" sub woofer, Alpine type-R front speakers. 16.249 @85.11mph 1/4 mile
2001 Pontiac Trans Am WS6 - Cam, headers, HPtuned by me.
David_viny is offline
post #5 of 25 (permalink) Old 10-21-2006, 06:54 PM Thread Starter
i hope this is not the case my car is lowerd alot and to even see the starter i have to jack it up
Stevie G is offline
post #6 of 25 (permalink) Old 10-21-2006, 07:10 PM
razzibird's Avatar
Send a message via AIM to razzibird
is the selenoid clicking or even making noise?
My car has seen its days.
razzibird is offline
post #7 of 25 (permalink) Old 10-21-2006, 10:46 PM Thread Starter
not at all. when i turn the key all the way the only thing that happens is the volt meter drops quite a bit, and things dim a little bit. im hopein on my battery, checkin that out tomorrow
Stevie G is offline
post #8 of 25 (permalink) Old 10-21-2006, 11:21 PM
wether's Avatar
sounds like the solenoid. . . . .I would hit it with a rubber mallet and see if it works after that. If so, then it is the solenoid/starter. => Replace starter.
wether is offline
post #9 of 25 (permalink) Old 10-22-2006, 03:45 AM
You should be able to start it with a screwdriver...
Turn the key on, while on jackstands, and short the solenoid wire to the main hot wire with a screwdriver... I used to start my old tbird like that for a while, while I was a broke high school student...
If it will start, you have a problem with the main key switch; its on the lower part of the steering column, as I recall.
You can add a bypass switch into the harness, and wait untill something else goes out; it makes it more theftproof...only you know where the starter is.
Grog6 is online now
post #10 of 25 (permalink) Old 10-22-2006, 10:56 AM
Don't make the same mistake I did. Check the ignition switch FIRST. It's a $17 part that takes 10 min. to change. Mine was heavily worn and burnt from arcing when I dissected it.
'97 XR-7 Sport w/4.6-- guess what color!
laser_red is offline
post #11 of 25 (permalink) Old 10-22-2006, 07:39 PM Thread Starter
i think i found out my problem, i guess in the engine swap the guys that did it didnt connect the passenger side ground. i can see it its hanging like right below the ac pully still attached to the block, i had my brother hold it to the k-member and i tryhed starting it but still the same old thing happened. Is there a new place i can make up a passenger side ground?
Stevie G is offline
post #12 of 25 (permalink) Old 10-22-2006, 10:43 PM
Maxion$Mulla$'s Avatar
looks like the battery is dead... anyone wanna bet??? :P
Kevin
94 t-bird parting out in the classifieds
Selling a Panasonic cd player 40x4 with 1 set of preouts
and a Yamaha warrior front fender- yellow Classified as SPEED DEMON! Mutha
Maxion$Mulla$ is offline
post #13 of 25 (permalink) Old 10-22-2006, 10:47 PM
The Stevinator's Avatar
yeah, my vote is on the starter solenoid.
The Stevinator is offline
post #14 of 25 (permalink) Old 10-22-2006, 10:52 PM Thread Starter
its not the battery i hooked up a pair of jumpers today to a friends car. im placing my bet on the igniton start switch I HOPE. im gonna jack it up tomorrow and try jumping the 2 posts on the starter if it cranks it should be the switch then, right?
Stevie G is offline
post #15 of 25 (permalink) Old 10-22-2006, 10:55 PM
Go for it. Just remeber play it safe
Kevin
post #16 of 25 (permalink) Old 10-23-2006, 11:36 PM Thread Starter
?? please
Stevie G is offline
post #17 of 25 (permalink) Old 10-24-2006, 07:40 AM
wether's Avatar
No, the solenoid could still be bad. All this does is short across the solenoid taking it out of the circuit.
wether is offline
post #18 of 25 (permalink) Old 10-24-2006, 03:23 PM Thread Starter
woww im really ****t now, i did the jump thing and the engine started up! i didn't have a belt on and rad hoses conencted so i quickly shut it off. i hook up everything and go to jump the 2 posts agin and the frigin thing sounds like its not engaging the starter motor is just spinnin its *** off. what the hell do i do now? im about to call the junkers and take the 1100$ hit
Stevie G is offline
post #19 of 25 (permalink) Old 10-24-2006, 03:46 PM
wether's Avatar
If it sounds like the starter is just spinning, then the starter is definately bad. . . .this is the bendix (sp?) being bad. Replace the starter and you should be good to go!
wether is offline
post #20 of 25 (permalink) Old 10-24-2006, 03:47 PM
wether's Avatar
BTW. . .it sounds like the solenoid may not have been the complete problem with the starter. . . .
wether is offline
post #21 of 25 (permalink) Old 10-24-2006, 04:02 PM Thread Starter
lol screw my life ......and my knuckles
Stevie G is offline
post #22 of 25 (permalink) Old 10-24-2006, 08:38 PM Thread Starter
i have been doing a search on the forums and i can't find 1 thred where this has happened to someone else, is it possible to be something other than my starter
Stevie G is offline
post #23 of 25 (permalink) Old 10-24-2006, 10:00 PM
rbrown's Avatar
If the starter just sounds like it is running but the car does not try to start go get a starter. The spring is not engaging the gear to the flywheel any more.
As a side, once you take it off, they can test it.
91 Festiva 1.3L baby 5 speed
10 Flex Brick Twin Turbos
*Rodney*
rbrown is offline
post #24 of 25 (permalink) Old 10-24-2006, 10:06 PM Thread Starter
didn't think of that, thank you.
tomorrow ill try and get that thing off i hope to god the shop didn't put the 3rd bolt back on
thanks every1 so far who has posted helpfull info for me
Stevie G is offline
post #25 of 25 (permalink) Old 10-25-2006, 07:49 AM
wether's Avatar
This is a "common" starter failure symptom. I remember when I was about 15 and just starting to work with my step dad at his shop. . . .we had an old '87 Aerostar that had the same problem with the starter, but the first time he asked me to go get it and pull it around to the garage I thought that I had broke something on his shop vehicle. He just laughed and told me it was the starter. . . .
The only other thing that can make a remotely similar noise is the gear ring breaking loose from the flexplate and I have NEVER heard of this happening with these 4.6's. If this were the case then you would have also hear a loud "Bang" when it broke loose.
wether is offline
