help - TCCoA Forums
post #1 of 6 (permalink) Old 10-22-2006, 12:44 PM Thread Starter
Exclamation help
i replaced intake manifold checked all vacuums, engine idels fine but when you
push thr gas it runs rough.
icouldreally need some help
Hetzel is offline
post #2 of 6 (permalink) Old 10-22-2006, 01:32 PM
Warlockguitarman's Avatar
Send a message via AIM to Warlockguitarman Send a message via Yahoo to Warlockguitarman
is there any coolant in the plug holes, take an air compressor and pull out the plug wires and blow in them, that is a comon quick problem that it could be, if it doesnt wix it sorry wait for other ideas
96 pearl white 4.6 tbird: rebuilt npi block with pi heads, pi intake, crower stage 2 cams, shm high lift springs, L-MAF, 3.73's, marauder converter, jmod, kooks headers, xpipe, no cats, 2.5 in exhaust, no mufflers, a dyno tune, lots of interior work, 1 in drop with lots of new bushings, 18 in rims. 279 hp 319 tq. curently running 13.9 at 101 mph with a 2.1 60 time in 100 degree weather while having some nasty spark knock. Soon to have higher stall, aftermarket intake manifold, weight reduction, and hopefully a nice shot of the giggle gas.
Warlockguitarman is offline
post #3 of 6 (permalink) Old 10-22-2006, 04:48 PM
try cleaning for maf sensor and see what that does. If that dont work the like he said wait for other ideas.
biggin002 is offline
post #4 of 6 (permalink) Old 10-22-2006, 04:52 PM
95xbird's Avatar
It doesn't run rough at an idle????Check all vacuum lines and look for a leak.Use a spray bottle to check them.
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #5 of 6 (permalink) Old 10-22-2006, 05:01 PM
Peter M's Avatar
Define rough. Does it fell like it's missing under load? If so, one of the plug wires may not be completely seated. It's happened to me before.
Peter M
SOLD 1996 4.6l Thunderbird-(fast) PI intake, custom exhaust, Bullet-Resistant Tranny™, blah, blah, blah
2007 VW GTI-(faster) United Grey, 18" wheels, APR stage 1 chip, and... uh... that's it for now.
________________________
..this space for rent..
Peter M is offline
post #6 of 6 (permalink) Old 10-22-2006, 05:17 PM
VicRattlehead's Avatar
recheck all the wires make sure ya put they are on the right plugs.
and
if you touched it, recheck it.
CMP Drag Racing
VicRattlehead is offline
