Check Gauges - TCCoA Forums
post #1 of 5 (permalink) Old 10-24-2006, 11:57 AM Thread Starter
Importskyline22's Avatar
Send a message via AIM to Importskyline22 Send a message via Yahoo to Importskyline22
Check Gauges
Im kinda confused. Lately my check gauges light comes on. Only when i turn thou, or shift the weight in the car.
Ive check my fluids, Oil is fine, power steering is fine, coolant is fine. So im a bit confused at what it could be.
Any suggestions?
Importskyline22 is offline
post #2 of 5 (permalink) Old 10-24-2006, 12:08 PM
This light will come on when the key is in the ON position and the:
- engine coolant temperature gauge is high, or
- engine oil pressure gauge is low, or
- when the fuel tank has reached empty reserve.
This light serves as a reminder for you to check the engine coolant temperature gauge, the engine oil pressure gauge or the fuel gauge. It will come on if there is a condition that needs your attention.
I would guess either you are low on gas or it is something dealing with that if your oil pressure isn't dipping low when are turning or stopping.
Bangster is offline
post #3 of 5 (permalink) Old 10-24-2006, 01:28 PM
Im gonna go with being a bit low on brake fluid.
PearlBirdSC is offline
post #4 of 5 (permalink) Old 10-24-2006, 01:45 PM
If brake fluid was low, the Brake light would illuminate, not check gauges.
Bangster is offline
post #5 of 5 (permalink) Old 10-25-2006, 11:07 PM
94mncougar's Avatar
Send a message via AIM to 94mncougar
Does your Oil Sender move when you do this? I've heard that the senders go bad. If that is the case (you have a good oil level and the sender is indeed bad) then it would be a good time to upgrade to a real pressure sender (look at the articles in progress).
- Stephen
Winter mods included:
- Developing Rocker Rust
- Saggy Suspension - fixed!
- Chipped paint
- I'm sure more to come... TOTALED
94mncougar is offline
