tips on removing a/c compressor ? - TCCoA Forums
post #1 of 3 (permalink) Old 10-25-2006, 07:26 AM Thread Starter
seanb's Avatar
Send a message via AIM to seanb
I searched, but nobody seems to be having the same difficulty as me. What is the easiest way to get to the compressor bolts? I can't seem to fit a socket in there cause the pulley is in the way. Tried to remove the pulley but only the front came off. Any help is appreciated.
rusty steel wheels, Trans-Go shift kit ( soon to be removed), Alpine + Clarion speakers, Sony cassette head unit, Addco 1.25 rear sway bar, Tokico shocks, PBR GT calipers
seanb is offline
post #2 of 3 (permalink) Old 10-25-2006, 08:44 PM
3rd Gear Chirper
hotbird's Avatar
try a box wrench, or even an open end. the open end may round off the corners if the bolts are tight so try the box wrench first.
hotbird is offline
post #3 of 3 (permalink) Old 10-25-2006, 09:03 PM
jesusraybrown's Avatar
Try two swivels, an extension, and definately some gloves to protect yer knuckles. Good luck.
1. This forum requires that you wait 30 seconds between sending private messages. Please try again in 266079416 seconds. wtf?
jesusraybrown is offline
