TicktickticktiVrooom! - TCCoA Forums
post #1 of 5 (permalink) Old 10-25-2006, 02:24 PM Thread Starter
Trumpeter Extraordinaire
IronChopz's Avatar
Oh yay...another thread about a starting problem.
My car encountered a charging/starting problem recently; mainly, the battery was nearly dying at long traffic lights during nighttime driving, and the telltale "tick tick tick" of a dying battery while starting the car was encountered a few times.
I replaced the alternator about 1½ weeks ago, since a local shop diagnosed a problem with it. Everything in the starting/charging system tested ok -- except that on a full load, the voltage was drawing from the battery, draining the battery. It was explained that a diode in the alternator was faulty, and causing that situation. After the replacement was installed, all was well.
Several days later, the ticking returned, and starting became nearly impossible (causing Enterprise Rent-a-Car to make a few bucks off me), so I replaced the starter solenoid. All was well.
Until late yesterday/this morning. The ticking started up again! I connected a "jumpstart battery" before continuing to start the car, charged the battery for half a minute, and the car started right up.
A visit to the shop that tested the charging system previously was made; all tests passed! They suggested that it may be a problem with the battery cables...
...which does make sense, though a quick exam shows no corrosion at the points where the cable connects to the battery. I have encountered faulty cables when dealing with stereo and computer components before, so it's possible a battery cable could be failing.
What's new:
1. Alternator
2. Starter solenoid
3. Battery (1/04)
4. Igintion switch (2003?)
I was wondering if anyone else has encountered something similar, and what your remedy was. I'm ready to get new cables, plus "Big 3" them, but I figured I'd research a little before doing so.
Thanks for your input.
--Pete
IronChopz is offline
post #2 of 5 (permalink) Old 10-27-2006, 02:02 PM
I had an interrmittent, recurring problem like you said. The thing that really struck me was the tick tick tick noise. Is it a noise like a clock, and does it sound like it is coming from under the steering column? I had that clock noise, and intermittently I would get no crank, and sometimes my whole car would lose power, ie nothing electrical worked.
After paying a mechaninc 200+ in diagnostic labor, the ultimate cost was $1.50 for a bad jumper wire on the antitheft box. The wire was melted from shorting so much. now it starts every time no start. Check all the anti theft relay wiring.
All Glory to God!
RIP JOHNNY LANGTON
96 LX PI/Jspec Pearl White. She enjoys eating ricers for breakfast
-MODS-
2002 PI 4.6L - Jspec Trans built by Darrin - 04 Marauder converter - Hayden 679 Trans cooler - Engine cooling modification - SCT Xcal2, tuned by Lonnie - 02 GT MAF and 99 GT Intake tube - removed silencer - 255 lph HP fuel pump - Aluminum Driveshaft - 3.73 TL - 245/60/15 BFGoodrich Radial T/A's - PBR front brakes - SCP Rear torsional load brace - SCP Solid rubber motor, transmission mounts - Rear Strut Tower brace and Diff cover brace by Rod
96_LX is offline
post #3 of 5 (permalink) Old 10-27-2006, 04:39 PM
02 Explorer Pioneer
timb's Avatar
Have you ever replaced the starter? I'm also currious about how you replaced the solonoid when it is integrated into the starter itself
Birdless
timb is offline
post #4 of 5 (permalink) Old 10-27-2006, 04:41 PM
The Great Obucina's Avatar
did you run a new engine to frame ground cable? Mine caused many electrical issues. including battery drain, no start, low charge, etc..
"Booyah". Stu Scott.
The Great Obucina is offline
post #5 of 5 (permalink) Old 10-28-2006, 12:33 AM Thread Starter
IronChopz's Avatar
All are good suggestions. Thank you.
96 LX -- what you describe is what I believe I'm hearing. I've not encountered a no start situation yet, but there's a dealer-installed antitheft device, more than likely installed for the original owner (I got the car in '97). Definitely worth a check.
timb - I have not replaced the starter, since the shop diagnostics indicate it's ok. I want to suspect it a little, though I don't know why. Regarding the solenoid, there are two T-20 bolts holding the solenoid to the starter. Undo those, remove the housing seal, and carefully slide the solenoid off.
The Great Obucina -- not yet. I'm not certain which one that is, though I am strongly considering new cables, as well as "The Big 3." Any additional insight about that cable is appreciated.
Thanks again, guys.
