misfire - TCCoA Forums
post #1 of 4 (permalink) Old 10-26-2006, 05:31 PM Thread Starter
fat_stan's Avatar
misfire
I've been having a misfire after I replaced the heater core (originally thought it was a vacuum leak). While the car was running I unplugged the spark plug wires one at a time from each ignition coil tower terminal. I got arching at every ignition coil tower except two of them... the ignition coil on the passenger side of the car, ignition coils tower terminals 3 and 5. Is there a test that can be performed on the ignition coil to make sure that ignition coil is pooched?
Stan
97 4.6L t-bird
Someday the good Lord will get me, but the law never will.
fat_stan is offline
post #2 of 4 (permalink) Old 10-27-2006, 01:47 AM
Peter M's Avatar
If you want, you could swap the packs. If the problem follows the pack, voila!
If the problem stays, it could be the wiring harness to the pack, or the EEC.
Peter M
SOLD 1996 4.6l Thunderbird-(fast) PI intake, custom exhaust, Bullet-Resistant Tranny™, blah, blah, blah
2007 VW GTI-(faster) United Grey, 18" wheels, APR stage 1 chip, and... uh... that's it for now.
________________________
..this space for rent..
Peter M is offline
post #3 of 4 (permalink) Old 10-27-2006, 11:29 AM
are u getting a "check engine light"?
tlpru is offline
post #4 of 4 (permalink) Old 10-29-2006, 06:05 PM Thread Starter
fat_stan's Avatar
thanks for your guidance guys. i swapped the coil packs and everything is working just great. must of been a bad connection or ground on the packs themselves.
97 4.6L t-bird
fat_stan is offline
