A/C problem - TCCoA Forums
post #1 of 6 (permalink) Old 10-26-2006, 09:04 PM Thread Starter
Question A/C problem
At times my air condition work and then it stops. And the defrost works for a little while and then stops? What could be the cause of this. I charged the air. BUt that did no good. Please help.
LeAndrew Coates
LeAndrew Coates is offline
post #2 of 6 (permalink) Old 10-26-2006, 10:08 PM
Your description is a bit vague. You said you charged it yourself, but did you have the proper equipment to do so or did you just slap on the regrigerant to the charging hose and fill up?
If it works and then cuts out, this probably is due to one of the following:
1) The system is low on refrigerant
2) The system is overfilled
3) There is moisture in the system
4) There is a problem with the A/C Clutch Cycling Switch
5) There is a problem with the CCRM
6) Airflow to the condensor is restricted
post #3 of 6 (permalink) Old 10-26-2006, 11:09 PM Thread Starter
The system was charged by me. I didn't take the time to use the proper equipment I may have to recharge the system morning.
LeAndrew Coates
post #4 of 6 (permalink) Old 10-27-2006, 11:59 AM
When you say sometimes it runs and sometimes it doesn't exactly what is running or not?
Is the blower/fan inside the car shutting on/off?
Is the compressor coming on and going off?
Do you have auto climate control?
More info will be needed to assist you.
55Customline_Sedan is offline
post #5 of 6 (permalink) Old 10-27-2006, 07:18 PM
Ckeck the two wire connector between the blower motor speed controller and the blower motor itself (behind the glove compartment). These are known to develop bad contacts over time.
Last of Breed is offline
post #6 of 6 (permalink) Old 10-27-2006, 10:36 PM Thread Starter
The compressor is not even coming on.
LeAndrew Coates
