About do to oil change. - TCCoA Forums
post #1 of 11 (permalink) Old 10-27-2006, 02:15 PM Thread Starter
TwoHaggard's Avatar
this has prolly been talked about lot.. i just dno what to pick.
my bird has just hit 70thousand n its time for a oil change..n i wanna do synthetic. what brand do u guys like best?, 10w30? 5w30?, n full syn or semi, and ill prolly do a motorcraft filter. any1 know the part # for that filter?
thx dank
Project still in progress
Explorer engine, vortech v2,intercooled,bullit intake,derale power steering cooler, b&m trans cooler, oil filter relocation, cobra aluminum radiator, Walbro 255 Pump, Intrax 2in lowering springs, KYB front/back,,mark8 Driveshaft, 1.25Rear sway bar, 3:73 aluminum diff, TrackLok, Rear Diff Cover Brace, Sc Wheels 235/60s, Jmodd, Air Bags in Springs,Rear strut Bar,17in Mirror Blk CobraRs, Sc L Brackets, rear torsional load brace, kmember-frame brace, weightloss program, pbr dual pistons drilled/slotted, stainless lines , recaro seats, sct x4 DonL tuned
TwoHaggard is offline
post #2 of 11 (permalink) Old 10-27-2006, 02:34 PM
Awaiting E-Mail Confirmation
tinman_72's Avatar
I have had extremely good fortune with every Ford that I have used Motorcraft oil and filter in, including my 4.6.
tinman_72 is offline
post #3 of 11 (permalink) Old 10-27-2006, 02:53 PM
I'll second that
I did go full synthetic with 130,000 miles, but my valve covers started to leak.
I picked up the motorcraft 10-30 from wal mart. The filter you need is listed in their book.
SlowProject is offline
post #4 of 11 (permalink) Old 10-27-2006, 03:05 PM
girdnerg's Avatar
Oil filter is Motorcraft FL820S. I use Mobil 1, 10w-30 full synthetic.
Rob
girdnerg is offline
post #5 of 11 (permalink) Old 10-27-2006, 03:07 PM
5w30 Mobil1 full synthetic.
fl-820s Motorcraft filter.
when I can get 5w30 Motorcraft semi synthetic for cheap I will use it, but I generally use Mobil1, I use the 15k mile stuff in my 4.6 powered Grand Marquis, the 5k mile stuff in the 97 Cougar.
Bangster is offline
post #6 of 11 (permalink) Old 10-28-2006, 04:17 PM Thread Starter
TwoHaggard's Avatar
ill prolly go full synthetic 10w30 with a the motorcraft filter then..idno what brand oil tho.
post #7 of 11 (permalink) Old 11-02-2006, 08:40 PM
DennisIsEvil's Avatar
Oil Filter is Motorcraft FL820S for the oil I used Valvoline 10W30 full synthetic.
"You get more with a smile and a gun than you get with just a smile."
-Al Capone
DennisIsEvil is offline
post #8 of 11 (permalink) Old 11-02-2006, 08:48 PM
95xbird's Avatar
I use the FL820S Motorcraft filter and 5w30 full synthetic mobil 1 oil.The filter is reasonable at walmart.I believe it is $3.28 plus tax. Cant buy a better oil filter for it.
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #9 of 11 (permalink) Old 11-02-2006, 09:01 PM Thread Starter
TwoHaggard's Avatar
ya ima do that filter. n proly valvoline or penzoil oi,l i put the car away for winter..so when i bring it back out ill do it
post #10 of 11 (permalink) Old 11-02-2006, 09:05 PM
95xbird's Avatar
Well you might wanna do it now and then 3 months do it again.Buy cheap oil for the winter just to start it every now and then.If you dont you will build condisation.Then when spring hits throw in some synthetic.
Its slow, Really.
LS1 KILLER
95xbird is offline
post #11 of 11 (permalink) Old 11-03-2006, 12:30 AM
Joseph Rice's Avatar
Send a message via AIM to Joseph Rice Send a message via MSN to Joseph Rice Send a message via Yahoo to Joseph Rice Send a message via Skype™ to Joseph Rice
At 199,100 I still use Pennzoil 5w30 and a Fram Extreme Guard. I will say gas milledge is very well.
Joseph Rice is offline
