DOHC Swap - TCCoA Forums
post #1 of 9 (permalink) Old 10-28-2006, 01:08 PM Thread Starter
Thread Killer
midwestbird's Avatar
DOHC Swap
Heres the link to the swap.....http://www.lincolnvscadillac.com/showthread.php?t=25280
As of 10-20-06 DOHC POWERED
Painted Vista blue as of 08
242hp/251tq
[email protected] [email protected] Byron Il
RobertP plate modded: 5-23-08
midwestbird is offline
post #2 of 9 (permalink) Old 10-28-2006, 06:12 PM
Grats! That engine looks sweet in there.
55Customline_Sedan is offline
post #3 of 9 (permalink) Old 11-03-2006, 09:01 AM Thread Starter
Thread Killer
All I have to say is the DOHC is awesome, way better than the SOHC!! Got to drive it home from the exhaust shop last night...Im glad I did it.
242hp/251tq
post #4 of 9 (permalink) Old 11-04-2006, 03:32 PM
SuperNewbie
supergordo's Avatar
Originally Posted by midwestbird
First off id like to personally thank you for posting such a detailed set of pictures!
Im getting ready to do the same swap myself very soon, and those will help me for sure.
Can you describe any other pitfalls, or things you needed to complete the job? Or simply anything you consider important if you were gonna do it again?
Was the "mule motor" just a junkyard find that you cleaned up?
Thanks again!
Gordon
Maybe you can post the pictures directly on Tccoa and and maybe the Mods can make your thread a sticky for future reference.
1995 Cougar XR7 4.6
1997 Thunderbird LX 4.6
1977 Country Squire 460
1985 Capri RS 5.0, 5spd
1997 Thunderbird 4.6
1984 Capri RS 5.0,5spd
supergordo is offline
post #5 of 9 (permalink) Old 11-06-2006, 09:57 AM Thread Starter
Thread Killer
There were no real pitfalls...The motor was a $500.00 junkyard special (came with wire harness and air cleaner and coolant hoses). There are some things like throttle cable and sensors that need to from the Mark. If you have question feel free to pm me. I couldnt have done it without the help of Toombs and Racecougar, so Ill be glad to help.
242hp/251tq
post #6 of 9 (permalink) Old 11-06-2006, 11:49 AM
Silenced's Avatar
I'm going to be doing this swap early next summer if everything goes smoothly financially.
Are those Kooks the same as the ones for the 2v? I have no idea.
Also, can someone suggest me a good MAF size for 4v applications? I don't plan on going much past a stock DOHC.
Silenced is offline
post #7 of 9 (permalink) Old 11-06-2006, 12:10 PM
Fry Rice Specialist
Casper's Avatar
the kookswill be different at the flange. 2v is round hole while 4v will be slot oval.
CarDomain Page
Casper is offline
post #8 of 9 (permalink) Old 11-06-2006, 01:59 PM Thread Starter
Thread Killer
The Kooks were from Supercoupe Performance, I told him what I was doing and he sent me the correct ones. I would suggest talking to Lonnie at Blue Oval Chips..he can set you up with a MAF and the programming for it.
242hp/251tq
post #9 of 9 (permalink) Old 11-06-2006, 05:35 PM
Nope, as Casper already mentioned, the exhaust ports are different between the 2V and 4V.
The stock Mark 8 80mm MAF would be just fine for a relatively stock DOHC (I'm currently running one on my setup).
-Rod
