question on idle - TCCoA Forums
post #1 of 15 (permalink) Old 11-06-2006, 03:17 PM Thread Starter
Question question on idle
how would be able to get a lower idle on 95 4.6 fuel injected motor i heard a clip of a guy on here who had a real low idle i forgot his handle on here but i think he called his car the beast?
biggin002 is offline
post #2 of 15 (permalink) Old 11-06-2006, 03:58 PM
What rpm does yours idle at now??
I don't know why you would want it lower, but I guess that could be done via a tune/chip.
Jay
FordMan77 is offline
post #3 of 15 (permalink) Old 11-06-2006, 05:31 PM
If I'm thinking of the same car you're referring to, his idle only SEEMS lower than stock due to the aggressive aftermarket cams he is running.
-Rod
post #4 of 15 (permalink) Old 11-06-2006, 06:33 PM Thread Starter
how much would a set of 8 aggressive aftermarket cams cost and how difficut would it be for a do it yourselfer?
post #5 of 15 (permalink) Old 11-06-2006, 06:39 PM
You don't need that many cams!
post #6 of 15 (permalink) Old 11-06-2006, 07:06 PM
Gcline's Avatar
did you put two quad 4 motors together or something?
Daily Driver, 38mpg!
Gcline is offline
post #7 of 15 (permalink) Old 11-06-2006, 07:08 PM
It's QOHC.
post #8 of 15 (permalink) Old 11-06-2006, 08:32 PM Thread Starter
im sorry i was tanking of something completly different sorry guys how much would 2 cams cost and how difficult would it be for a do it yourselfer?
post #9 of 15 (permalink) Old 11-07-2006, 09:50 PM
jesusraybrown's Avatar
You could get comp 262's for around 300 on corral if you're lucky. If you're gonna cam it, you may as well do a pi swap while it's down. Difficulty would be measured by your mechanical ability, and confidence in knowing you wouldn't **** anything up. If you want to do it yourself see if you could find someone who's done a cam/headswap before, and see if they'll help you with it. BTW, where in Missouri are you?
1. This forum requires that you wait 30 seconds between sending private messages. Please try again in 266079416 seconds. wtf?
jesusraybrown is offline
post #10 of 15 (permalink) Old 11-09-2006, 10:58 AM Thread Starter
what would the pi swap consist of and im from sedalia its in central missouri
post #11 of 15 (permalink) Old 11-09-2006, 11:16 AM
The pi swap would be H/C/I, with various hoses, and ****. But you'd want the 262's instead of the pi cams. You can buy a full pi swap kit on ebay, but they're a little pricey. Look on Corral for everything. You could get pi heads, and intake for 2-300, and the 262's for maybe 300. That'd be money well spent. Then $50 for labor if you can find someone near you to do the swap for beer, food, and gas. Good luck.
post #12 of 15 (permalink) Old 11-09-2006, 01:10 PM Thread Starter
what is the actually web it for corral?
post #13 of 15 (permalink) Old 11-09-2006, 01:21 PM
http://www.corral.net/
Jay
post #14 of 15 (permalink) Old 11-09-2006, 04:46 PM
Maxion$Mulla$'s Avatar
$600 for Livernoise bullit cams... probally the best you can buy. http://livernoismotorsports.com/
and buy a service manual... it a pretty dificult job... plan on having your car off the road for a couple of days but im warning you if your going into this with no knowlege at all. your probally better off going to service or perfomance shop. L8ter
Kevin
94 t-bird parting out in the classifieds
Selling a Panasonic cd player 40x4 with 1 set of preouts
and a Yamaha warrior front fender- yellow Classified as SPEED DEMON! Mutha
Maxion$Mulla$ is offline
post #15 of 15 (permalink) Old 11-12-2006, 08:36 PM
twin turbo 281's Avatar
my car has a lower lopey idle due to aftermaket cams. Im using NonPI heads with the comp cams XE 268/274 114LSA. i poped them in without degreeing them and still running the stock convertor and computer.
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
