Question about bbk pullys. - TCCoA Forums
post #1 of 6 (permalink) Old 11-07-2006, 02:21 PM Thread Starter
TwoHaggard's Avatar
Hey guys i was just wodering if these pullys fit.. there 1996-Current 4.6 Mustang Underdrive pullys aluminum part # is. bbk1555 i have a 95 4.6 bird
Thx dank
Project still in progress
Explorer engine, vortech v2,intercooled,bullit intake,derale power steering cooler, b&m trans cooler, oil filter relocation, cobra aluminum radiator, Walbro 255 Pump, Intrax 2in lowering springs, KYB front/back,,mark8 Driveshaft, 1.25Rear sway bar, 3:73 aluminum diff, TrackLok, Rear Diff Cover Brace, Sc Wheels 235/60s, Jmodd, Air Bags in Springs,Rear strut Bar,17in Mirror Blk CobraRs, Sc L Brackets, rear torsional load brace, kmember-frame brace, weightloss program, pbr dual pistons drilled/slotted, stainless lines , recaro seats, sct x4 DonL tuned
TwoHaggard is offline
post #2 of 6 (permalink) Old 11-07-2006, 02:50 PM
They'll fit.. As far as I know there's two different part numbers on pulleys.. pre mid '99 and mid 99' and newer 4.6l engines.. something about the water pump that makes them different, can't remember exactly... just make sure you get the pre '99 part....
Justin McC
Stinkfist04 is offline
post #3 of 6 (permalink) Old 11-08-2006, 08:35 PM Thread Starter
TwoHaggard's Avatar
so u think they will fit?
post #4 of 6 (permalink) Old 11-08-2006, 09:36 PM
Traveler's Avatar
The year that is different is 02 (pretty sure anyway) they changed them halfway through the year. So I think they'll fit. Do a search, its been discussed here before.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #5 of 6 (permalink) Old 03-12-2007, 01:49 PM Thread Starter
TwoHaggard's Avatar
these pullys are 1996-2000 4.6 and Cobra, so u think they will?
post #6 of 6 (permalink) Old 03-12-2007, 02:20 PM
The Great Obucina's Avatar
if they work for a 96 GT, they will work for your car.
"Booyah". Stu Scott.
The Great Obucina is offline
