Cobra + 3V = Easier install? - TCCoA Forums
post #1 of 9 (permalink) Old 11-07-2006, 07:34 PM Thread Starter
CEO, WT Club
GODSPEED's Avatar
Originally Posted by BIG PETE
Hmm...if the belts fit fine, maybe converting an 03 Cobra motor to the 3V GT belt layout could be a possibility?
Pete
Back in the thread about the 3v stang engine in the 'Bird, this was brought up. Would the front cover and such even fit? Where would this relocate the alt to even if it was a possibility? I just wanted to thrash this idea around some more, so all comments are welcome... When the time comes, I'm gonna make this work no matter what (03-4 Cobra w/ whipple), just want to look at the options.
-Joel
Previous MN12s:
GODSPEED is offline
post #2 of 9 (permalink) Old 11-07-2006, 07:51 PM
i'm pretty sure the alternator could be relocated, depending on what other accessories you plan to keep. you could do something like this:
http://www.sullivanperformance.com/Y...electrical.htm
careful man, i've seen a couple 3 valve threads spin waaaay out of control in the last week.
whatever you end up doing, i'm in complete support.
boba is offline
post #3 of 9 (permalink) Old 11-07-2006, 09:12 PM Thread Starter
CEO, WT Club
GODSPEED's Avatar
Well, this shouldnt spin outta control, I dont wanna use a 3v. Just find the easiest way to get the motor in the car.
-Joel
Previous MN12s:
GODSPEED is offline
post #4 of 9 (permalink) Old 11-07-2006, 09:16 PM
Illinois Chapter Director
TydlwavS's Avatar
Send a message via AIM to TydlwavS
Delete the A/C and put the alternator over there with a custom bracket or find a place to flip it around in the belt layout (like the AED). I was looking at the A/C delete option pretty hard with the 03 swap. It would have given me a lot more room and better cooling and the car was going to see limited driving.
From my old measurements I think you might be able to notch the inner rail and weld in plates to support it. I can't recall if there was going to be an issue with front subframe bolt access, but I know something stopped me from going that route.
"That is the worst looking car in the whole world. I'd rather look at one of your dingle berries"
Check out what we've been up to....
http://forums.tccoa.com/forumdisplay.php?f=54
TydlwavS is offline
post #5 of 9 (permalink) Old 11-08-2006, 07:20 AM
03 cobra motor fits fine in the fn-10/mn-12 platform just fine. Modify the top alt bracket and it's a go.
No need to relocate anything except the oil filter, but that's a no brainer with the livernois adapter.
My motor ready to go in:
It's in ...it's in ...
Mad1stGen is offline
post #6 of 9 (permalink) Old 11-08-2006, 07:51 AM Thread Starter
CEO, WT Club
GODSPEED's Avatar
What is the issue with the fuel system? Something about the returnless style? Also, how much room do you have when you modify the upper brakcet? I will be using this car to it's full potential, and dont want any flex to be a problem either. Mad1stgen... did you just build the top end of your mark motor? I know you're using the mark computer... would it be so easy to just swap the mark computer into a bird?
-Joel
Previous MN12s:
GODSPEED is offline
post #7 of 9 (permalink) Old 11-08-2006, 07:52 AM Thread Starter
CEO, WT Club
GODSPEED's Avatar
I WILL be keeping the a/c... if I can get it working again.
-Joel
Previous MN12s:
GODSPEED is offline
post #8 of 9 (permalink) Old 11-08-2006, 07:56 AM Thread Starter
CEO, WT Club
GODSPEED's Avatar
Back to the thing at hand though, would the 3v FEAD system work?
-Joel
Previous MN12s:
GODSPEED is offline
post #9 of 9 (permalink) Old 11-08-2006, 11:35 AM
BIG PETE's Avatar
Ha! So the alternator did clear! That's awesome! All this time, I thought that it wouldn't fit around the k-member... Maybe I should have gone with one of those instead of the route I took afterall? I originally brought up that thread to see about the viablility of taking the 3v's alternator and belt layout and swapping it to the front cover of the 03-04 Cobra motor. The cost on these shortblocks is starting to drop, and it's a good way to get a DOHC powerhouse that's already got forged guts from the factory. I wasn't really interested in the Eaton, since the shortblock is prime for a Vortech that would clear the stock hood, but if the Eaton was there, that's great too though!
Anyways, what's wrong with the fuel system? Can't you just use the fuel rails from a 96-97 style bird?
Pete
-97 XR-7
-5.0 Big Bore ...
Density Altitude = 4132'
1/8 mile: 8.75 @ 82
BIG PETE is offline
