Cam gears? - TCCoA Forums
post #1 of 13 (permalink) Old 11-07-2006, 08:59 PM Thread Starter
281_TBird's Avatar
Cam gears?
Hey all, I'm planning on getting PI heads, a PI intake, and Comp 262 Cams with the Comp Valve springs over the winter. It's my understanding that aftermarket cams need to be degreed in but that that requires adjustable cam gears. As far as I know, Fidanza is the only company that makes them but that they are junk and fail. Can somebody point me in the right direction? Thanks.
281_TBird is offline
post #2 of 13 (permalink) Old 11-08-2006, 09:44 AM
SR-71Blackbird's Avatar
mine was fine with the stock gears
1997 4.6L LX SPORT, rollin on 19's
http://www.cardomain.com/ride/856858
http://s12.photobucket.com/albums/a241/steviewonder13/
PI heads, PI intake, Comp 262's, Comp Valve Springs, Kooks headers, 3.73 TL, 180*T-stat, RSTB, lowered 1.5", A/C Delete Pulley, Custom exhaust. Block #2
-- SCT dyno tune 279RWHP & 310RWTQ - DD tune, SAE corrected
14.5 @ 97mph (need a higher stall, car bogged w/ stock converter + mickeys, lol)
SR-71Blackbird is offline
post #3 of 13 (permalink) Old 11-08-2006, 11:10 AM
The Great Obucina's Avatar
the 262s will be fine, you will need a tune though. I would go with Crower cams instead.
"Booyah". Stu Scott.
The Great Obucina is offline
post #4 of 13 (permalink) Old 11-08-2006, 06:20 PM Thread Starter
281_TBird's Avatar
So its not really necessary to degree them in? Also, Obucina what grind of Crowers would you suggest?
post #5 of 13 (permalink) Old 11-08-2006, 07:15 PM
Moderator & Teksid Whore
guitar maestro's Avatar
something similar to the comp cams 262s would be the crower 62811-2 (stage 2 grinds or the high-lift PI-grind 62801-2 (PI stage 2)
guitar maestro is offline
post #6 of 13 (permalink) Old 11-08-2006, 08:29 PM Thread Starter
281_TBird's Avatar
Thanks for the suggestions guys, I think PI Heads, these cams, and probably a trick flow intake are going to be a great combo for my car. I think I will probably do a set of kooks as well, if i decide not to do a 5-speed swap (but I really want to) I will for sure be getting a converter with more stall and a 4.10 ring and pinion.
post #7 of 13 (permalink) Old 11-09-2006, 10:07 PM Thread Starter
281_TBird's Avatar
Do you think the 268's would work with with the stock cam gears? If use these cams though I would definately get a higher stall converter and/or lower rear end gears.
post #8 of 13 (permalink) Old 11-10-2006, 01:18 AM
im pretty sure you would have to degree them in to make sure there is no PTV contact with the 268s
post #9 of 13 (permalink) Old 11-10-2006, 01:28 AM
their "Stage 2" hi lift if for the PI heads. Its very smiliar to the 262AH cams.
i dont recommend Comp for personal reasons....
post #10 of 13 (permalink) Old 11-12-2006, 08:16 PM
twin turbo 281's Avatar
you can ground off the cam key on the stock gears and they become adjustable. I didnt go this route i just bolted the cams up. Dialing in the cam timing is a good way to eek out the best performance. In a new article by MM& FF they messed with cam timing on the mod motors and found reliable power increases.
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #11 of 13 (permalink) Old 11-14-2006, 04:34 PM Thread Starter
281_TBird's Avatar
Hmm, I think it will come down to whether or not I can degree them in the car because I am not taking the engine out, I do not have a stand or a means to get it out with so I am somewhat limited.
post #12 of 13 (permalink) Old 11-15-2006, 02:27 AM
Refrigerator Raider Hater
GreenBird's Avatar
just shave off what you need to on the stock gear's key.
Always degree your cams, no matter how tame the profile. It's about a correct setup, not just having enough clearance.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #13 of 13 (permalink) Old 11-15-2006, 02:33 PM
TGJ
Baddest N/A NPI in Canada
TGJ's Avatar
If you are referring to the same Stg 2 Crowers I have, they are almost identical to the Comp 270AH cam.
TGJ is offline
