Block of instruction---EGR Valve--- - TCCoA Forums
post #1 of 10 (permalink) Old 11-07-2006, 11:54 PM Thread Starter
Awaiting E-Mail Confirmation
BIRD-OF-PREY's Avatar
What is it, where is it, and how do I replace it?
Is it more cost efective to take it to a shop?
Thanx in advance.
BIRD-OF-PREY is offline
post #2 of 10 (permalink) Old 11-08-2006, 12:50 AM
Since you have a 95, I will admit..it's a pita.
It's behind your intake, and the only way I could gain access to it was to remove the wiring, fuel rail assembly, and intake.
If you have the tools, I'd say save yourself quite a bit of money and do it yourself.
95XR7 is offline
post #3 of 10 (permalink) Old 11-08-2006, 04:37 AM Thread Starter
I found a guy that will do it for 160 what do you think?
post #4 of 10 (permalink) Old 11-08-2006, 07:18 AM
wether's Avatar
I would say if he will do it for 160 then let him do it. . . . .just my thoughts.
wether is offline
post #5 of 10 (permalink) Old 11-08-2006, 04:42 PM
Tx_Cat's Avatar
No way, to much money to just change the EGR. Buy yourself the Haynes manual and o it your self. Dont be lazy! It will be easier and you will learn. Sh!t, I did by my self the exploder swap in my 95 couagr without the knowledge, and 5 mechanics were I lived told me that it was not doable, so when I was done, I took the car to them and show them, they were like SOB's dont know nothing, that's why I do not let any mechanics touch my car anymore.!
Tx_Cat is offline
post #6 of 10 (permalink) Old 11-08-2006, 04:49 PM
girdnerg's Avatar
I'd disconnect the egr tube from the exhaust manifold and pull the entire intake. That way you can clean the intake passages really well while you're in there.
Rob
girdnerg is offline
post #7 of 10 (permalink) Old 11-08-2006, 05:24 PM
Carlover007's Avatar
Can't you just get the SCT chip to turn it off?
Carlover007 is offline
post #8 of 10 (permalink) Old 11-08-2006, 08:19 PM
rbrown's Avatar
Question is why do you need to replace it?
rbrown is offline
post #9 of 10 (permalink) Old 11-11-2006, 01:59 AM Thread Starter
To answer you question rbrown, we got a read out, (code) at Autozone. Im in Kuwiat, now so the Misses Had to handle it, we ended up paying 250, total. it took the gut 2 days to do it, but she seams to be happy with it.
I am Lazy, but if it would have saved me 250, juct call me Jesse Owens
post #10 of 10 (permalink) Old 11-12-2006, 02:51 PM
rbrown's Avatar
Got it done. Good job. Keeping the misses happy is most important
rbrown is offline
